Lpc2000
Texas Instruments have TMS470 datasheets on their web now
2005-01-25 by tsvetanusunov
The info for TMS470 actually have been on TI web site for years but
they never made the datasheets public, as didn't want to deal with
small customers.
Now TI changed their mind and the datasheets for the first three
members are already on the web.
The budgetary pricing for their TMS470R1A256 with 256K Flash 12K RAM
is $6.85/1K
(and yes I'm biased as the only development board on TI web available
is ours :)
Best regards
Tsvetan
PCB prototypes for $26 at http://run.to/pcb
(http://www.olimex.com/pcb)
PCB any volume assembly (http://www.olimex.com/pcb/protoa.html)
Development boards for ARM, AVR, PIC, and MSP430
(http://www.olimex.com/dev)
Re: Texas Instruments have TMS470 datasheets on their web now
2005-01-26 by Rick Collins
I think this is a very interesting development.  I have been asking TI
about their ARM CPUs for a couple of years.  Since they are willing to
sell their parts (although there is nothing available even as samples
just yet) I have started a Yahoo group for the TMS430 ARM parts.
http://groups.yahoo.com/group/TMS470_ARM/
(this time I remembered to post the link!)
To Tsvetanusunov, what TMS430 chip is on your board?  Is it the
TMS470R1A256?  The web site does not actually say and they list both
the 256 and the 128 as "related devices".  Is this board currently
available?  The TI site says status is "preview".  Will you be selling
it directly?  $400 is a bit steep for such a simple board, even if it
includes a simple JTAG dongle.
--- In lpc2000@yahoogroups.com, "tsvetanusunov" <tusunov@m...> wrote:
> Hi,
> small customers.
> is $6.85/1K
> is ours :)
> Best regards
> Tsvetan
2005-01-26 by tsvetanusunov
TI
to
samples
selling
it
on board is with TMS470R1A256 the only difference with 128 is that it
have more memory so this is why they say board cover the development
for both devices.
The board is available and TI sells it now in bundle with Segger's J-
Link.
I can't comment the price, this is TI policy. Segger retial for J-
Link only is 400 Euro, so looking at this side the deal looks like
bargain ;)
This board was designed exclusively for TI and TI only sells it.
We are developing our own header, proto and Ethernet boards which
will be available around May this year when the TMS470 devices will
be available through TI disty channels.
Best regards
Tsvetan
Boy, I sure seem to be good at making mistakes.  Just to make it
clear, the group I started is for the TMS470 ARM parts, not the TMS430
part.  The link is correct.    Sorry...
> TI
> to
> samples
> selling
> it
> for both devices.
> Link.
> bargain ;)
> Best regards
> Tsvetan
[lpc2000] Best solution for multiMCU comm
2005-01-26 by Marko Pavlin (home)
Hello!
I would like to connect several P89LPC932 (x51 core) slaves to single
LPC2xxx master. Each slave has unused SPI and UART, which can be used
for this communication. One slave is addressed at once.
What would be best solution for that? I think SPI is ideal for that. I
could use free port pins for slave selects. Is there any other (more
scalable) option without external/additional components? How many slaves
can I connect to single master to avoid port overloading? Data transfer
rate is very low (~100 bytes/s per slave) and distance between master
and slaves is <1m.
Any further suggestions or tips&tricks?
M.
Re: Best solution for multiMCU comm
2005-01-26 by donhamilton2002
> Data transfer
master
> and slaves is <1m.
Unless you have a very large board ( <1m ), using an RS-485 would be
the easiest way to get running.
Using a scheme like MODBUS is also easy on software.
There are many projects on the web using slimmed downed version of
MODBUS that you might leverage.
hamilton
2005-01-27 by embeddedjanitor
--- In lpc2000@yahoogroups.com, "Marko Pavlin (home)" <mp@h...> wrote:
> Hello!
single
used
that. I
(more
slaves
transfer
master
> and slaves is <1m.
> M.
If you had CAN controllers on your devices then I'd say use that. You
don't need all the differential stuff to run CAN, just hook up all
the RX pins (and TX pins via diodes) and add a pull-up.
Are all these micros on one board? If so, you can use the same scheme
as above with UARTS. That is, make a "1-wire" bus where all the rx
lines are joined together, all tx lines are attached to the 1-wire
through a diode, a pull-up. You just need some sort of protocol so
that the devices don't all talk at the same time.
If they're on different boards, then RS485 is the easiest way to go
multi-master.
Re: [lpc2000] Best solution for multiMCU comm
2005-01-27 by Peter Jakacki
I have to say that the UART solution is the easiest and the best
although it's a pity that Philips implemented a PC style UART on the ARM
(no 9-bit mode). But with the 16-byte FIFO it does take some of the load
off the CPU.  The SPI approach suffers for many reasons, mainly because
there are no buffers and so incurs a high overhead. But never rule it
out, do your sums first, it may be fine in your app.
For a hardware interface I would not bother with diodes and pullups but
rather tie the rx and tx lines together on the CPU and then couple this
to a common coms bus through a current limiting resistor (say 100 -
220ohms) for those recalcitrant nodes. A very light pullup will be
needed to keep the line high when inactive. You can always disable the
transmitter output when listening and it still has plenty of drive,
especially for higher speeds. Then again, the diode/pullup option has
some advantages too. No need for 485 unless you are running
higher-speeds/longer distances.
CAN is ideal for this application but unfortunately the 932s don't have
them.
*Peter*
Marko Pavlin (home) wrote:
>Hello!
>and slaves is <1m.
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.7.5 - Release Date: 1/26/05
2005-01-27 by Robert Adsett
You can do 9 bit on a 16550 (at least a real one) using a technique I've
seen referred to as parity modulation.  The ideas is to use 8 bit with mark
or space parity.  You set up the UART to interrupt on a parity violation
and then set it to space parity.  When you receive a character with mark
parity you get an interrupt and that's your 'address' byte.  Just as with
normal 9 bit you can then switch receive all characters if selected or just
wait for the next parity violation.
I may have the sense of whether to use mark and space backwards, it's been
a while.  And I have no idea if the nearly compatible UART in the LPC's can
do it or not.
If the lines stay on board I'd certain consider SPI, but I'm always
reluctant to run TTL signals off board unprotected.  You could use 232 or
485 style drivers I suppose but at that point you might as well use the
UART and save the select pins.
>them.
Depending on what you need to pass around another automotive derived
signalling spec to look at is LIN, fewer wires and less communications
capability (lower baud, fewer and smaller packets) than CAN.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
> >them.
And what I didn't point out, uses a UART.
Robert
                         Kelvin Throop, III
2005-01-27 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Thursday, January 27, 2005 5:13 AM
Subject: Re: [lpc2000] Best solution for multiMCU comm
>> >them.
Atmel has an app note on a software LIN technique for the AVR.
Also, EDN has this neat design idea:
http://www.edn.com/article/CA484493.html?spacedesc=designIdeas
Leon
Internal Virus Database is out-of-date.
Version: 7.0.300 / Virus Database: 265.7.1 - Release Date: 19/01/2005
