Lpc2000
Pulse Width Modulator
2005-01-26 by teunvandeberg
Hello,
I'm trying to use PWM 5 on a LPC2292. How can I select which timer is
used for the PWM. Can someone give some example code? I can't get any
output on the pin. It is configured as PWM5.
We use FreeRTOS so the following code is used to setup Timer 1:
 * Setup the timer 0 to generate the tick interrupts at the required
frequency.
static void prvSetupTimerInterrupt( void )
unsigned portLONG ulCompareMatch;
	/* A 1ms tick does not require the use of the timer
prescale.  This is
	defaulted to zero but can be used if necessary. */
	T0_PC = portPRESCALE_VALUE;
	/* Calculate the match value required for our wanted tick
rate. */
	ulCompareMatch = portCPU_CLOCK_HZ / portTICK_RATE_HZ;
	/* Protect against divide by zero.  Using an if() statement
still results
	in a warning - hence the #if. */
	#if portPRESCALE_VALUE != 0
		ulCompareMatch /= portPRESCALE_VALUE;
	#endif
	T0_MR0 = ulCompareMatch;
	/* Generate tick with timer 0 compare match. */
	T0_MCR = portRESET_COUNT_ON_MATCH | portINTERRUPT_ON_MATCH;
	/* Setup the VIC for the timer. */
	VICIntSelect &= ~( portTIMER_VIC_CHANNEL_BIT );
	VICIntEnable |= portTIMER_VIC_CHANNEL_BIT;
	/* The ISR installed depends on whether the preemptive or
cooperative
	scheduler is being used. */
	#if portUSE_PREEMPTION == 1
		extern void ( vPreemptiveTick )( void );
		VICVectAddr0 = ( portLONG ) vPreemptiveTick;
	#else
		extern void ( vNonPreemptiveTick )( void );
		VICVectAddr0 = ( portLONG ) vNonPreemptiveTick;
	#endif
	VICVectCntl0 = portTIMER_VIC_CHANNEL | portTIMER_VIC_ENABLE;
	/* Start the timer - interrupts are disabled when this
function is called
	so it is okay to do this here. */
	T0_TCR = portENABLE_TIMER;
Could this be causing the problem?
Kind Regards,
Teun
