Lpc2000
LPC213x SSP Controller
2005-01-28 by lp2000c
We recently migrated a design from LPC2124 to LPC2138.  We assumed
that when they converted SPI1 to SSP, they added functionality, but
did not remove any of the existing functionality.  We discovered,
that they removed the option of having it transmit LSB first.
We can work around it by reorganizing how a bunch of our data is
organized, but it's bit of a pain.
They also eliminated some of the error flags (e.g.: Mode Fault, Slave
Abort, Write Collision).
Caveat Emptor!  (Or did I miss something?)
Re: [lpc2000] LPC213x SSP Controller
2005-01-28 by Robert Adsett
Well as far as the error flags, the FIFO will make the write collision less
likely, that flag probably just didn't make sense to keep.  As far as
Master/Slave faults (which are the other two) the user manual looks rather
confused about the issue.  It seems to be referring to system behaviour
rather than peripheral behaviour.
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
