Lpc2000
RE: [lpc2000] Question: Secondary JTAG internals
2004-02-04 by Milos Prokic
Rod,
Thanks! I will definitely tweak my power circuit to supply 3.3 V first and
then 1.8 keeping the reset low until 1.8 reaches 95%.
Best regards,
Milos
Sent: Wednesday, February 02, 2005 10:14 PM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Question: Secondary JTAG internals
> Philips has stated, and my experience has been, that there is not a
> sequencing issue on power up.  I suspect you've got something else going
> on.  I've not used the secondary JTAG myself, but it does appear to
> cause people no end of troubles.
I have been using the secondary JTAG on several different LPC2106 designs
(with different revs of both the chip and boot-loader) since the summer of
2004 and have not had a single problem.
On a side note. All of the designs had 1.8V regulators that fed off of the
3.3V mains and only let the LPC2106 out of reset after the 1.8V was in
spec and then only after a delay in the order of hundreds of milliseconds.
- Rod
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
2005-02-02 by Milos Prokic
I was wondering if anyone has any information regarding the secondary JTAG -
internal structure. I'm battling a problem that I can only connect to JTAG
after I've SHORTed the 3.3 V line. My powerup sequence is - first core
(1.8v) and then IOs (3.3v) (btw there is nothing in the datasheet that
mentions the sequence, so I presumed it wouldn't matter). Without shorting
the tool will refuse to connect, but once shorted - works like a charm.
I'm trying to understand the problem behind this. What I'm not sure how is
this presumably muliplexor setup by the core, and how does it stay set after
the core resets. Anyway, I'm out of ideas at this point, but this simple yet
annoying problem is bugging the hell out of me.
Thanks for any insight!
Cheer,
m.
2005-02-02 by Robert Adsett
on.   I've not used the secondary JTAG myself, but it does appear to cause
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Robert,
Thanks. The thing is that I built this board myself so I'm guessing that it
is due to my negligence of some kind and not the chip's fault. I tested the
Sec. JTAG prior to this implementation and it seemed to work just fine on
the Ashling LPC dev board. I wasn't gonna clone that board, so I obviously
don't have the same power section.
How could one explain the fact that shorting 3.3V supply will somehow
kickstart it?.. beats me. I tried all kinds of tricks.. holding the reset,
shorting individual JTAG pins.
I'll keep poking it in during some off hours :-)
m.
  _____
Sent: Tuesday, February 01, 2005 11:34 PM
Robert
                         Kelvin Throop, III
  _____
Yahoo! Groups Links
2005-02-02 by Owen Mooney
I am using the secondary JTAG on the LPC2106 - its fine. I have done it with a modified Olimex P1 board and my own board
They both use different brands of regulator with no start up sequencing, and a simple RC reset circuit.
Having said that, the secondary JTAG on the first of my boards (3 V up then 1.8 up) spat the dummy and worked intermittanly, then refused to work properly. I built another prototype and that works perfectly.
Not an answer for you - but more information to the digest.
Cheer,
m.
2005-02-03 by Milos Prokic
Ok. so you're saying that having 3.3V first, than 1.8V works fine now? That
is you did not change anything from the first prototype to second to fix the
JTAG inconsistencies?
Thanks for the info!
m.
  _____
Sent: Wednesday, February 02, 2005 5:14 PM
Subject: [lpc2000] Question: Secondary JTAG internals
Cheer,
m.
  _____
Yahoo! Groups Links
2005-02-03 by Rod Moffitt
- Rod
