Lpc2000
RTOS....freeRTOS or Rowley's?
2005-02-04 by Gus
Hello,
How does Rowley's tasking library compare to FreeRTOS? Spee? foot
print?
I am about to start a project and not sure whitch one is better!
Any thoughts from Rowley's people?
Gus
Re: RTOS....freeRTOS or Rowley's?
2005-02-05 by nutleycottage
Hi Gus,
Here are speed/footprint numbers of CTL for an LPC21xx running at
60Mhz with MAM enabled.
Premptive task schedule - i.e. time to reschedule a higher priority
task after an ISR has executed.
ARM   4,468 bytes  7.48 uSecs
THUMB 3,124 bytes  8.24 uSecs
Co-operative task schedule - i.e. time to reschedule a higher priority
task due an API call from a task e.g. a semaphore signal.
ARM   3,984 bytes  5.38 uSecs
THUMB 2,848 bytes  5.44 uSecs
So you're looking at 3K/4K of code overhead.
A task stack will require at least 34 words (136 bytes) - which is a
number I hope to reduce somehow/sometime this year.
Michael
> Hello,
> print?
> Gus
