Philips Flash Utility V2.2.1 question
2005-02-11 by gregdeuerling
I have a program that has several 16x16 tables that are stored in fixed locations in flash memory. I'm using Keil's compiler and using the _at_ attribute to do this, it works great. My tables change quite often but the code does not change at all. I'd like a way to be able to reprogram just the tables in flash and not touch the code section. I was wanting to use Philips Flash Utility (PFU from here on) to program JUST the table locations I want to change. I generate a hex386 file of just the table data and fire up the "Flash Buffer Operations" in PFU and load the hex file. My new tables show up exactly where they are supposed to be, but when I hit the "Upload to Flash" button PFU programs the entire flash memory. I have the "selected range" button selected with the proper range in it. The only way I've gotten this to work is to open the orginal hex file into a text editor and append the new table hex file to the end of it. Can I not just program certain pages in flash and leave the rest alone? Thanks...
