Lpc2000
IAR Flash Programming
2005-02-17 by lp2000c
After IAR released EWARM version 4.20A, one of my colleagues
discovered a bug in their flash programming for the LPC chips.  It
will not let you program the last sector of flash (the one before the
bootloader).
IAR has posted a fix (as well as flash programming support for
LPC2138) in the Technical Support section of their website.  (Select
IAR Embedded Workbench Support, search for reference number 50187.)
Thanks H.S.
Re: IAR Flash Programming
2005-02-18 by Leighton Rowe
Thanks for the info. Does the flash programmer on EWARM 4.20A have
the ability to erase flash? I'm not sure that the programmer on the
version I'm currently using (EWARM 4.10B) can do this.
Leighton
> bootloader).
(Select
> Thanks H.S.
2005-02-22 by lp2000c
I'm not sure.  I never had reason to use IAR to erase without
programming.  I don't see any obvious way to do this, but a call to
IAR should be able to prvide an answer.
BTW: Philips utility can do this.
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
> Thanks,
> Leighton
2005-05-04 by irahorden
> Thanks,
> Leighton
It
> the
> > bootloader).
> (Select
50187.)
>>>>>>>>>>>> That note is # 51087 - ih
> > Thanks H.S.
