GCC runing optomization!
2005-02-18 by Gus
2005-02-18 by Gus
Hello, Anyone is using GCC compiler version 3.4.2 WITH optomization? When I enable optomization, my applicatin acts funny! I am not sure why. Gus
2005-02-18 by Bryce Schober
I'm not using 3.4.2, but in general: We use extensive optimization in all of our products (we couldn't live without it). Without optimization gcc basically creates paranoid assembly code. With optimization, gcc basically assumes that you said exactly what you mean when you wrote your code, which isn't always true. Perhaps the most common problems are variable declarations. When a variable can change outside the current scope (for example, in an interrupt), it must be declared as volatile so that the compiler won't assume that the variable hasn't changed since the last time it was accessed. That was the most common problem I've run into. On Fri, 18 Feb 2005 17:52:07 -0000, Gus <gus_is_working@...> wrote: > > Hello, > > Anyone is using GCC compiler version 3.4.2 WITH optomization? > > When I enable optomization, my applicatin acts funny! I am not sure > why. > > > Gus > > > > > ________________________________ > Yahoo! Groups Links > > To visit your group on the web, go to: > http://groups.yahoo.com/group/lpc2000/ > > To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. -- Bryce Schober
2005-02-19 by jane highland
Gus, The rule with optimisation e.g. -O3 : If a function calls a function outside of the current 'C' module, the function will definately be called. If a function calls another function which calls another function etc. inside the SAME module, it may not compile as expected (some of the calls may be optimised out) UNLESS the FINAL function in the chain accesses something volatile, or is an external function (to the module). e.g. * (volatile unsigned long fred) * FRED = 0; This is because the scope of the optimiser is limited to the current module only - it has no idea about external functions and there leaves any calls to them intact. But functions inside the same module may just magically dissappear if they're deemed not to access anything useful (volatile). I learned the hard way over several days! Jane --- Gus <gus_is_working@...> wrote: --------------------------------- Hello, Anyone is using GCC compiler version 3.4.2 WITH optomization? When I enable optomization, my applicatin acts funny! I am not sure why. Gus --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/lpc2000/ To unsubscribe from this group, send an email to: lpc2000-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ___________________________________________________________ ALL-NEW Yahoo! Messenger - all new features - even more fun! http://uk.messenger.yahoo.com
2005-02-20 by embeddedjanitor
--- In lpc2000@yahoogroups.com, "Gus" <gus_is_working@y...> wrote: > > Hello, > > Anyone is using GCC compiler version 3.4.2 WITH optomization? > > When I enable optomization, my applicatin acts funny! I am not sure > why. > > > Gus I have had no problems using various versions of gcc, at various optimisation levels. As others have said,check your volatile declaraions.
