Lpc2000
Timer 1 Interrupt problem in LPC2106
2005-02-21 by mannem_sri
I am trying to generate an interrupt using Timer1 in LPC2106.
I put 0xff in match register.
The timer is incrementing and restting whenever it matches the match
register value.
But it is not generating the interrupt when match occurs.
I am running my program from SARM. I have done the memory mapping
also.
I have written the program with referrence of AN10254.
I am using arm compilers to build the project.
Please help me in getting the interrupt.
If you have anu exampled programs please send it to me.
Thanks in advance.
-Srinivas.
RE: [lpc2000] Timer 1 Interrupt problem in LPC2106
2005-02-21 by Milos Prokic
Did you enable the timer interrupt in the timer module?
Did you set the following registers accordingly -  VICIntSelect,
VICIntEnable,  VICVectAddrX ,VICVectCntlX ?
Did you enable the interrupts globally, ie in the core (status register)?
m.
  _____
Sent: Monday, February 21, 2005 3:31 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Timer 1 Interrupt problem in LPC2106
register value.
also.
Thanks in advance.
-Srinivas.
Yahoo! Groups Sponsor
<http://us.ard.yahoo.com/SIG=129s5mq14/M=324658.6070095.7083352.3001176/D=gr
oups/S=1706554205:HM/EXP=1109061053/A=2343726/R=0/SIG=12if5c1ch/*http:/clk.a
tdmt.com/VON/go/yhxxxvon01900091von/direct/01/&time=1108974653580313>
oups/S=1706554205:HM/EXP=1109061053/A=2343726/R=1/SIG=12if5c1ch/*http:/clk.a
Get unlimited calls to
U.S./Canada
<http://view.atdmt.com/VON/view/yhxxxvon01900091von/direct/01/&time=11089746
53580313>
<http://us.adserver.yahoo.com/l?M=324658.6070095.7083352.3001176/D=groups/S=
:HM/A=2343726/rand=260539174>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
2005-02-22 by Srinivas
Hi Milos,
Yes, I have enabled the timer interrupt in timer module.
And i have initialized the VIC registers also.
Please have a look at that register values.
/*Timer initialization */
	TIMER1_TCR = 0x0;				// Reset
//	TIMER1_TC = 0x0;				// Timer Counter
	TIMER1_PR = 2500;				// Prescale register
//	TIMER1_PC = 0x0;				// Prescale Counter
	TIMER1_MR0 =1000;				// Match Register
	TIMER1_MCR = 0x3;				// Generate interrupt and reset when match occurs.
	/* Timer 1 interrupt is an IRQ interrupt */
	VICIntSelect &= ~0x20;
  /* Enable timer 1 interrupt */
  	VICIntEnable = 0x20;
  /* Use slot 0 for timer 1 interrupt */
  	VICVectCntl0 = 0x25;
  /* Set the address of ISR for slot 0 */
  	VICVectAddr0 = (unsigned int)IRQHandler;
	MSR cpsr_c,#0x13			// This assembly instruction for enabling the processor
interrupts.
Please have a look at the register values and let me know where i am doing
the mistake.
Thanks in advance.
-Srinivas.
Thanks and best regards,
Srinivas,
ARM-ODC,
Tata Elxsi,
Office : +91 80 22979581
Mobile : +91 98802 72705
Sent: Monday, February 21, 2005 9:58 PM
Subject: RE: [lpc2000] Timer 1 Interrupt problem in LPC2106
m.
  _____
register value.
also.
Thanks in advance.
-Srinivas.
U.S./Canada
53580313>
  _____
Yahoo! Groups Links
Yahoo! Groups Links
2005-02-22 by Milos Prokic
Hey,
Your VIC looks Ok
 so do the registers
 the only thing I see is that you
don’t have a line Timer1_TCR = 0x01 – to enable the timer
To enable interrupts you can use the following macro:
#define _EINT()							\
	asm volatile ( "stmdb	sp!, {r0}" );		\
	asm volatile ( "mrs	r0, cpsr" );		\
	asm volatile ( "bic	r0, r0, #0xC0" );		\
	asm volatile ( "msr	cpsr, r0" );		\
	asm volatile ( "ldmia	sp!, {r0}" )
Hope this helps,
m.
________________________________________
From: Srinivas [mailto:srinivasmannem@tataelxsi.co.in]
Sent: Tuesday, February 22, 2005 12:37 AM
Hi Milos,
interrupts.
the mistake.
Thanks in advance.
-Srinivas.
Srinivas,
ARM-ODC,
Tata Elxsi,
m.
  _____
register value.
also.
Thanks in advance.
-Srinivas.
U.S./Canada
53580313>
  _____
Yahoo! Groups Links
Yahoo! Groups Links
U.S./Canada
Yahoo! Groups Links
• To visit your group on the web, go to:
• To unsubscribe from this group, send an email to:
• Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
