Lpc2000
UART0 vs UART1
UART0 vs UART1
2005-02-25 by dimaissaev
Hi all.
Could anyone explane me what different between UART1 and UART0 (except
modem control register in UART1).
I can't understant NOTHING!
Two equal initialization. Equal ISR but when I try to work with UART1,
system hand-up. UART0 working absolutely normal. Exactly like in PDF,
without ANY problem.
Re: [lpc2000] UART0 vs UART1
2005-02-25 by Srinivasa Reddy Mannem
Could you please send me the code for UART0.
Here i am facing some problem with UART0.
I am unable to send any charector to Hyper Terminal..
Thanks in advance.
-Srinivas.
dimaissaev <dimaissaev@...> wrote:
Hi all.
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
Do You Yahoo!?
http://mail.yahoo.com
2005-02-25 by Robert Adsett
There are examples in the files download area.  The newlib-lpc library (
http://www.aeolusdevelopment.com ) has drivers for both UARTS both polled
and interrupt driven.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: UART0 vs UART1
2005-02-25 by peterburdine
I've been having a terrible time with getting the interrupts working
on the LPC2294 using the Keils tools.  The code being created seems
fine, but if I try and enable the interrupts, sometimes it will work,
sometimes they are ignored and sometimes the processor just locks up.
 I generally have to spend an hour or so trying to figure out what
order to initilize things in before they work.
--- In lpc2000@yahoogroups.com, "dimaissaev" <dimaissaev@y...> wrote:
> Hi all.
Re: UART0 vs UART1
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
library (
polled
I can't use this interrupt by many reason. The main is Ineed a nested
interrupts.
And I think that I have a problem with them.
Re: [lpc2000] Re: UART0 vs UART1
2005-02-27 by Robert Adsett
>library (
>polled
>interrupts.
They would still be a way to verify your own approach didn't leave anything
out though.
Which raises two questions
   Have you verified that you have working non-nested interrupts?  Always
get the simpler case to work first.
   Are you absolutely certain you need nested interrupts?
I strongly suspect that nested interrupts will require an assembly language
shim.  I would advise using such a shim even for standard interrupts but
not everyone shares my paranoia on that :)
Robert
                         Kelvin Throop, III
