Lpc2000
Reset time
Reset time
2005-02-25 by Danilo Franco
Does anyone know how much time (or instruction cycle) RST line must be pulled down to reset LPC2138?
Danilo
Re: Reset time
2005-02-25 by charlesgrenz
Morning Danilo,
  80ms if you need to use one. Since the 2138 has a POR circuit, you
do not need any external reset control.
regards,
Charles
> Regards,
> Danilo
ARM7 with on-board ethernet
2005-02-25 by Hugh O'Keeffe
Hi Group,
I know that Philips are releasing an LPC2000 part later this year (Q3
according to Rober's last post) with on-board ethernet. Anyone know of an
ARM7 based MCU available today with on-board ethernet ? Netsilicon is all a
quick google found for me.
Hugh,,
Re: [lpc2000] Re: Reset time
Hi Charles,
Thanks for your prompt reply.
So once POR is activated, what is the RST rise time? I have been designing reset control circuit taking into account that noise on this line could reset the microcontroller.
Danilo
  To: lpc2000@yahoogroups.com
  Sent: Friday, February 25, 2005 9:34 AM
  Subject: [lpc2000] Re: Reset time
  Morning Danilo,
  regards,
  Charles
  > Regards,
  > Danilo
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    http://groups.yahoo.com/group/lpc2000/
Re: [lpc2000] ARM7 with on-board ethernet
2005-02-25 by 42Bastian Schick
Hi Hugh
> all a
Samsung has one (it is on the ARM Evaluator-7T board, but ARM did not
place
a Phy-Chip beside it).
42Bastian Schick
Re: Reset time
Hi Danilo,
  There you have me. When I initially talked with Philips Apps about
this, they gave me the wrong information the first time and the second
time the 80 ms value. I would assume that since the "wake up timer" is
watching everything to make sure that all is up to snuff before
allowing execution to start. From 10ns to 100us or as soon as it
passes the 2.8V range.
regards,
Charles
> Hi Charles,
> Regards,
> Danilo
>   From: charlesgrenz
>   Morning Danilo,
>   regards,
>   Charles
>   > Regards,
>   > Danilo
>               ADVERTISEMENT
>   Yahoo! Groups Links
Service.
2005-02-25 by Jens Hildebrandt
Hugh O'Keeffe wrote:
> Hi Group,
> Thanks,
> Hugh,,
Hi Hugh,
first, the unfortunately now EOL-ed Samsung S3C4510B/4530A (50MHz ARM7TDMI) come to mind. Seems as
if Samsung dropped out of the network controller buissiness since they axed all their ARM7/ARM9
controllers with on-chip Ethernet.
Then, there is Sharp with their LH79524/79525 controllers (77 MHz ARM720T) aimed at the mobile
devices market.
All these are large 200+ pin monsters, no low-pincount controllers like the Philips LPC2xxx.
Some time ago, before Texas Instruments opened their TMS470 family to the mere mortals, there was a
list on their web site naming all the automotive TMS470 controllers they produce/intend to produce
and IIRC there was also a device with ethernet in a 100 or 120 pin package listed, but I can't find
that page now.
It seems that most ARM devices with an internal 10/100-Ethernet interface are ARM9s now, obviously
for performance reasons.
HTH,
Jens
2005-02-25 by Stephen Pelc
>    From: "Hugh O'Keeffe" <hugh.okeeffe@...>
> year (Q3 according to Rober's last post) with on-board
> ethernet. Anyone know of an ARM7 based MCU available today
> with on-board ethernet ? Netsilicon is all a quick google
> found for me.
See Sharp
  www.sharpsma.com
We haven't written the Ethernet drivers for these yet.
See Samsung
The S3C4510B is used by most of the low cost 10/100 4 port
switches/hubs. Unless they've improved the sample code in the
last 18 months, beware! The sample Ethernet driver is buggy, so
try for a Linux driver or contact me directly.
See Atmel AT91RM9200 if you don't mind an ARM9.
Note that integrated Ethernet hardware usually requires *much*
more code than external chips such as the SMC91C111 or the Asix
and Realtek chips.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 23 80 631441, fax: +44 23 80 339691
web: http://www.mpeltd.demon.co.uk - free VFX Forth downloads
Re: ARM7 with on-board ethernet
2005-02-25 by radoslaw_mitura
--- In lpc2000@yahoogroups.com, "Hugh O'Keeffe" <hugh.okeeffe@a...>
wrote:
> Hi Group,
(Q3
know of an
is all a
> Thanks,
> Hugh,,
There is one from ATMEL (AT91C140) with dual 10/100 MAC (but without
PHY) and SDRAM controller. It is quite big BGA256.
2005-02-25 by Gus
year (Q3 according to Rober's last post) with on-board ethernet.
Will this chip have PHY built in? If not, I really don't want to see
that chip! If yes, I can't wait to get samples :-)
Gus
>>Hi Group,
>>Thanks,
>>Hugh,,
> Hi Hugh,
> devices market.
> that page now.
> HTH,
> Jens
Oops, forgot one...
The Winbond W90N740 is an ARM7 based MCU with I- and D-cache running at 80MHz, featuring two
10/100-Ethernet-MACs, NAT-module, USB 1.1 host controller, UART, DMA controller, 24bit Timers and an
external bus controller supporting SDRAM and PCMCIA among others.
Jens
RE: [lpc2000] ARM7 with on-board ethernet
2005-02-27 by David Kay
Hi Jens,
Have you used the Winbond W90N740 before?
It is a nice looking part; I even have a demo board running uC Linux
sitting on my desk but I have been unable to get my hands on the device.
David Kay
www.adilam.com.au
> Jens
Oops, forgot one...
Jens
Yahoo! Groups Links
2005-02-28 by Joseph Goldburg
Yes,
Can any one source the Winbond W90N740  chips that is.
Joseph
Sent: Monday, 28 February 2005 7:40 AM
Subject: RE: [lpc2000] ARM7 with on-board ethernet
Hi Jens,
David Kay
www.adilam.com.au
> Jens
Oops, forgot one...
Jens
Yahoo! Groups Links
Yahoo! Groups Links
2005-02-28 by Jens Hildebrandt
Hi David,
up to now I have only considered that chip for a project that was eventually realized using another
IC. Back then, the data sheet on the Winbond page was only "preliminary" and since that company has
only one distributor here in Germany - which up to now seems not to know that chip at all - we
refrained from using it. Meanwhile, there exists a \ufffdCLinux port (if I did get the Google search
results right) based on a low cost router.
Maybe, to get hold of the chip you have to talk to Winbond directly but I guess you have to mention
large numbers to get them listening to you.
Jens Hildebrandt
David Kay wrote:
> Hi Jens,
> David Kay
> www.adilam.com.au
>>Jens
> Oops, forgot one...
> Jens
2005-03-02 by Alex Gibson
Josehp can you give me the pricing for any arm7 or other arm dev boards
you guys carry.
A couple of lecturers are looking for more boards for a uni embedded
systems subject.
May be 3 - 6 months or longer before they actually purchase any.
Just trying to find them some reasonably cheap boards
preferably with local supplier.
Thanks
Alex Gibson
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 266.5.1 - Release Date: 27/02/2005
