LPC2132 SPI problem
2005-03-02 by johnsonnenberg99
I just can't get the SPI port on the 2132 to work (master mode).
Any help would be MUCH appreciated!
I've setup the pin connect block per the manual, enable the SPI port
in the PCONP register, programmed the SPI registers, and then try to
send a byte. It appears to send in software, and the SPIF bit get
set, but nothing comes out the MOSI pin or the SCK pin (both stuck
low). I don't think I have a short on the PCB.
Here's the main sections of code
void OpenMasterSPI0(void)
PCONP_bit.PCSPI0 = 1; // enable the SPI hardware
PINSEL0 = PINSEL0 & 0xFFFF00FF; // set the pin-select
regisgters to enable the SPI pins
PINSEL0 = PINSEL0 | 0x00001500; // Enable SPI pins, but do not
use the Slave Select Pin. It is GPIO.
// set the pins to SPI
SPCCR0 = 128; // clk for the SPI clock.
SPCR0 = 0x20 ; // master mode, active high
clock, no IRQ
// Write a byte to the SPI, and also read one in.
char WriteReadSPI0(char b)
int i=0;
SPDR0 = b; // this write starts the spi transmission
i=0;
while( i == 0 )
i = (SPSR0 & 0xff); // wait till we are done.
return SPDR0;
Thanks in advance for any ideas.
