Lpc2000
My LPC2106 won't return from function calls
2005-03-04 by ooggie01
I'm trying to learn how to write C programs for my LPC-MT-2106 board
from Olimex.  I'm using the GNU toolchain for compiling/linking and
CrossWorks for programming the board.  I successfully got the LED to
blink; however, as soon as I introduced a function call, my code
won't work.  It still compiles/links/programs just fine, but the LED
won't change.  It seems like the processor never returns from any
function calls.  Any ideas why this may be?
I've included my code and makefile below.  The first program works
and the second one doesn't.
Thanks in advance!
Thomas
// led.c without function calls
/* General Purpose Input/Output (GPIO) */
#define IOPIN	(*((volatile unsigned long *) 0xE0028000))
#define IOSET	(*((volatile unsigned long *) 0xE0028004))
#define IODIR	(*((volatile unsigned long *) 0xE0028008))	// 0-
INPUT 1-OUTPUT
#define IOCLR	(*((volatile unsigned long *) 0xE002800C))
#define LEDMASK 0x00001000	// LED	P0.12
unsigned int i;
int main()
	IODIR = IODIR | LEDMASK;
	while(1)
		IOCLR = IOCLR | LEDMASK;
		for( i = 0; i < 50000; i++ )
		IOSET = IOSET | LEDMASK;
	return 0;
// EOF
// led.c with a function call
INPUT 1-OUTPUT
void delay( unsigned int i )
int main()
	while(1)
		delay( 50000 );
		delay( 50000 );
	return 0;
// EOF
// makefile
arm-elf-gcc -c led.c -o led.o
arm-elf-gcc -TLPCH40MB.LD -nostartfiles -o led.elf led.o
Re: My LPC2106 won't return from function calls
2005-03-04 by charlesgrenz
Wheres the stack point to?
regards,
Charles
> Thanks in advance!
> Thomas
> INPUT 1-OUTPUT
> unsigned int i;
> int main()
> 	while(1)
> 	return 0;
> // EOF
> INPUT 1-OUTPUT
> int main()
> 	while(1)
> 		delay( 50000 );
> 		delay( 50000 );
> 	return 0;
> // EOF
> // makefile
Re: [lpc2000] Re: My LPC2106 won't return from function calls
2005-03-04 by Robert Adsett
Actually if I read the code correctly he doesn't have any startup code at
all.  He could get away with that as long as there were no interrupts set
up and he made no function calls.  As soon as a function call is added or a
significant number of local variables. boom...
The first thing he needs to do is add that a startup.  There are a few in
the files section I believe.  There is also a startup file with the
newlib-lpc stuff.  It should useable even without the rest of the library
support http://www.aeolusdevelopment.com
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: [lpc2000] My LPC2106 won't return from function calls
2005-03-05 by Michael Anburaj
Hi Thomas,
Give this a try. You need to setup the SVC stack
before you can call functions from the entry point.
The simple application attached along with this should
run from both Flash & RAM (use tmon -- packaged along
with ucos_arm at my site).
http://geocities.com/michaelanburaj/controller.html
-Mike.
> LPC-MT-2106 board
> call, my code
> fine, but the LED
> returns from any
> program works
> Thanks in advance!
> Thomas
> 0xE0028000))
> 0xE0028004))
> 0xE0028008))	// 0-
> INPUT 1-OUTPUT
> 0xE002800C))
> unsigned int i;
> int main()
> 	while(1)
> 	return 0;
> // EOF
> 0xE0028000))
> 0xE0028004))
> 0xE0028008))	// 0-
> INPUT 1-OUTPUT
> 0xE002800C))
> int main()
> 	while(1)
> 		delay( 50000 );
> 		delay( 50000 );
> 	return 0;
> // EOF
> // makefile
> led.o
Celebrate Yahoo!'s 10th Birthday!
Yahoo! Netrospective: 100 Moments of the Web
http://birthday.yahoo.com/netrospective/
2005-03-05 by Michael Johnson
If you use CrossWorks to build the program then the startup code will be
included....
Michael
>Hi Thomas,
>Cheers,
>-Mike.
>>LPC-MT-2106 board
>>call, my code
>>fine, but the LED
>>returns from any
>>program works
>>Thanks in advance!
>>Thomas
>>0xE0028000))
>>0xE0028004))
>>0xE0028008))	// 0-
>>INPUT 1-OUTPUT
>>0xE002800C))
>>unsigned int i;
>>int main()
>>	while(1)
>>	return 0;
>>// EOF
>>0xE0028000))
>>0xE0028004))
>>0xE0028008))	// 0-
>>INPUT 1-OUTPUT
>>0xE002800C))
>>int main()
>>	while(1)
>>		delay( 50000 );
>>		delay( 50000 );
>>	return 0;
>>// EOF
>>// makefile
>>led.o
>Yahoo! Groups Links
