Lpc2000
LPC2138 Data Abort problem
2005-03-06 by david_z_lawson
I'm new to ARM / embedded / Philips. I've got some code that I've been
stepping through and one instruction is causing a data abort, I think,
since execution goes to 0x00000010 (the data abort vector). But core
interrupts are disabled. I guess that a data abort is not really an
interrupt. But what could cause this to happen?
on the MCB2130 / LPC2138:
r0 =    0x00000000
r1 =    0x4000f6f4
cpsr =	0x800000df
pc =	0x400000b4
strcc   r0, [r1], #4    <<<< causes 'data abort', goes to 0x00000010
thanks,
David
Re: [lpc2000] LPC2138 Data Abort problem
2005-03-06 by Robert Adsett
>r0 =    0x00000000
>r1 =    0x4000f6f4
>cpsr =  0x800000df
>pc =    0x400000b4
Doesn't the 2138 only have 32K RAM?  R1 is well above that point.  You are
trying to access an area to no memory.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
LPC 2xxx - Databus speed ?
2005-03-06 by Lasse Madsen
Hi All,
I have a quick "on the fly" question concerning the devices with external
data bus is their speed limited to the I/O speed of about 3,58MHz as well?
Best regards
Lasse Madsen
Re: LPC2138 Data Abort problem
> >r0 =    0x00000000
> >r1 =    0x4000f6f4
> >cpsr =  0x800000df
> >pc =    0x400000b4
You are
> Robert
>                          Kelvin Throop, III
You're right. I just tried defining 32k memory size in my linker file
and it works fine now. I thought that I read somewhere that this
processor had 64k of ram. I just looked it up and is says 32k.
David
2005-03-06 by Owen Mooney
And the real beauty of the LPC series is you can put a long jump at the data abort vector (or any other vector) - jump back to "main" (or where ever) and put up a little helpful message on your LCD display (or what ever) saying "Memory Error please contact your supplier." :-)
Owen
Subject: Re:
>>> >r0 =    0x00000000
>>> >r1 =    0x4000f6f4
>>> >cpsr =  0x800000df
>>> >pc =    0x400000b4
You are
>> Robert
>>                          Kelvin Throop, III
David
__________
It sounds like you've just re-invented the Blue Screen of Death :)
Robert
                         Kelvin Throop, III
