Lpc2000
RE: [lpc2100] Digest Number 62
2004-01-22 by Michael Johnson
Can someone explain what "Flash Programming via JTAG" means in this
thread. Have Philips published the JTAG scan chain that accesses the
Flash and has someone been courageous enough to use it? If the flash
programming is done by communicating with a RAM resident loader program
(which is how CrossWorks does it) I can't see that it makes much
difference if the primary or secondary JTAG port is used.
Michael
Message: 12
   Date: Thu, 22 Jan 2004 10:13:10 -0000
Subject: Re: Secondary JTAG problem. -> succesfull solution
--- In lpc2100@yahoogroups.com, "Hugh O'Keeffe" <hugh.okeeffe@a...>
wrote:
> Ashling have seen problems with the secondary debug port as well.
> Sometimes it works, sometimes it doesn't. We have been able to
> debug/flash via the secondary port, however, not consistently and
> reliably. From a recent batch of twenty of our EVBA7 boards we had
five
> secondary debug failures. We are confident we are doing the right
thing
> and that it is not a tool issue (we have reproduced the problem with
ARM
> MultiICE as well).
> Hugh @ http://www.ashling.com/support/lpc2100/
>  -----Original Message-----
> From: Jim Beagley [mailto:jim5272@h...]
> Sent: 21 January 2004 00:59
> To: lpc2100@yahoogroups.com
> Subject: [lpc2100] Re: Secondary JTAG problem. -> succesfull solution
> Using the Primary for program, and then switching to secondary for
> debug works fine. Attempting to program in Secondary mode fails at
> every attempt, and only serves to corrupt the currently flashed
> program, after which the primary port is required to aleviate the
> problem.
The following points out that that the secondary JTAG is *only*
intended for debugging:
http://www.semiconductors.philips.com/acrobat/applicationnotes/AN10255_1
.pdf
Leon
________________________________________________________________________
Yahoo! Groups Links
To visit your group on the web, go to:
 http://groups.yahoo.com/group/lpc2100/
 lpc2100-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
