Lpc2000
64-bit integer division problem in CrossWorks(r) for ARM
2005-03-10 by John Doe
Hi!
CrossWorks(c) for ARM has problem with 64-bit integer division when
one or both operands have value exceeds 32-bit capacity. This is
code below to work around.
Does somebody knows this is CrossWorks ARM library problem only
or also GCC ARM library has it ???
John Doe
<pre>
/* C-wrapper */
long long y_64div(long long a,long long b)
   y_div64();
   return b;
/* GCC ASM code - derived from ARM(c) macros */
   .text
   .code 32
   .align 4
   .global  y_div64
y_div64:
         STMFD   SP!,{R0,R1,R2,R3,R6-R11,R12,LR}
         ANDS      R9, R3, #1<<31               // get sign of d
         BPL        L_00
         RSBS      R2, R2, #0                   // ensure d +ve
         RSC        R3, R3, #0
L_00:
         EORS       R9, R9, R1, ASR#32           // b31=result b30=sign of n
         BCC        L_01
         RSBS       R0, R0, #0                   // ensure n +ve
         RSC        R1, R1, #0
L_01:
         BL          y_divu64
         MOVS     R9, R9, LSL#1                // get out sign bits
         BCC        L_02
         RSBS      R2, R2, #0
         RSC        R3, R3, #0
L_02:
         MOVS     R9, R9, LSL#1
         BCC        L_03
L_03:
         MOV        R4, R2
         MOV        R5, R3
         LDMFD    SP!,{R0,R1,R2,R3,R6-R11,R12,LR}
         BX           LR
y_divu64:
        STMDB    SP!, {R4,R5,R6,R7,R8}
        MOV        R4,#0                /* zero the quotient */
        MOV        R5,#0
        MOV        R7,R1           /* set the remainder to the current value */
        MOV        R6,R0
        ORRS      R8, R2, R3
        BEQ         LU_08                /* divide by 0 */
        MOVS      R8,#0                /* count number of shifts */
       /* first loop gets $d as large as possible */
LU_00:
        ADDS       R2, R2, R2
        ADCS       R3, R3, R3        /* double d */
        BCS         LU_01             /*  overflowed */
        CMP         R3, R7
        CMPEQ    R2, R6
        ADDLS      R8, R8, #1       /* done an extra shift */
        BLS          LU_00
        ADDS       R8, R8, #0       /* clear carry */
LU_01:                               /* carry the overflow here */
        MOVS       R3, R3, RRX      /* colour */
        MOV         R2, R2, RRX      /* shift back down again */
LU_02:
        SUBS        R0, R6, R2
        SBCS        R1, R7, R3       /* n = r - d and C set if r>=d */
        MOVCS     R7, R1
        MOVCS     R6, R0           /* r=r-d if this goes */
        ADCS        R4, R4, R4
        ADC          R5, R5, R5       /* shift next bit into the answer */
        MOVS       R3, R3, LSR#1
        MOV         R2, R2, RRX      /* shift down d */
        SUBS        R8, R8, #1
        BGE          LU_02            /* do next loop (t+1) loops */
LU_08:
        MOV         R2, R4
        MOV         R3, R5
        MOV         R0, R6
        MOV         R1, R7
        LDMIA       SP!, {R4,R5,R6,R7,R8}
        BX          LR
</pre>
Do you Yahoo!?
 Make Yahoo! your home page
Re: 64-bit integer division problem in CrossWorks(r) for ARM
2005-03-10 by moruisg
Which version of CrossWorks for ARM are you using? You can use "Help |
About CrossStudio" to determine the version and build number.
I can't reproduce the problem, so can you provide some source code
that demonstrates the problem you are seeing?
Jon Elliott
Rowley Associates Ltd
--- In lpc2000@yahoogroups.com, John Doe <ytremil@y...> wrote:
> Hi!
> Regards,
> John Doe
> <pre>
> /* C-wrapper */
>    y_div64();
>    return b;
>    .text
>    .code 32
>    .align 4
>    .global  y_div64
> y_div64:
>          BPL        L_00
>          RSC        R3, R3, #0
> L_00:
b30=sign of n
>          BCC        L_01
>          RSC        R1, R1, #0
> L_01:
>          BL          y_divu64
>          BCC        L_02
>          RSBS      R2, R2, #0
>          RSC        R3, R3, #0
> L_02:
>          MOVS     R9, R9, LSL#1
>          BCC        L_03
> L_03:
>          MOV        R4, R2
>          MOV        R5, R3
>          BX           LR
> y_divu64:
>         MOV        R5,#0
current value */
>         MOV        R6,R0
>         ORRS      R8, R2, R3
> LU_00:
>         ADDS       R2, R2, R2
>         CMP         R3, R7
>         CMPEQ    R2, R6
>         BLS          LU_00
> LU_02:
>         SUBS        R0, R6, R2
>         MOVCS     R7, R1
>         ADCS        R4, R4, R4
answer */
>         MOVS       R3, R3, LSR#1
>         SUBS        R8, R8, #1
> LU_08:
>         MOV         R2, R4
>         MOV         R3, R5
>         MOV         R0, R6
>         MOV         R1, R7
>         BX          LR
> </pre>
> Do you Yahoo!?
2005-03-10 by ytremil
--- In lpc2000@yahoogroups.com, "moruisg" <je@r...> wrote:
> Hi,
use "Help |
> Regards,
> Jon Elliott
This is a simple example:
long long a = 1767040273612800LL;
long long b = 2365440384LL;
long long c;
int main(void)
  c = a/b;
  return 0;
After division, "c"  has value 747009,but correct result - 747023.
Another few numbers:
  1767020750438400 / 2365439945 = 747015,
   but CrossWorks give 747008;
  1767001050316800 / 2365438870 = 747007,
   but CrossWorks give 746528 (!)
My CrossStudio(r) current version - 1.3 Build 5
(with ver. 1.2 - the same problem)
In LPC2106,S3C44B0X,ARM Simulator -  the same problem.
 Yuri Tiomkin,
 http://www.tnkernel.com
