Lpc2000
RealMonitor with LPC 2106
2005-03-11 by mannem_sri
I am silent member of this group. I am working on LPC2106.
I have developed an application using Timer and Interrupt for
LPC2106 target board .
Now i am trying to use the RealMonitor concept for my application.
Does anybody is working on this (RealMonitor with LPC2106)?
Please give me some inputs regarding this.
Like what i have to do if i want to use RealMonitor in my program?
Thanks for all hints.
-Srinivas.
Re: RealMonitor with LPC 2106
2005-03-24 by lpc2100
Try sample code given in the user guide. Do you have a debugger which
can talk to RealMonitor?
--- In lpc2000@yahoogroups.com, "mannem_sri" <mannem_sri@y...> wrote:
> Hi,
> Regards,
> -Srinivas.
2005-04-15 by mannem_sri
I am trying to use RealMonitor which is there in flash memory of
LPC2106. I have called all RealMonitor related functions in my
application program as per the document.
That project has compiled and linked without any errors.
But i am unable to connect the RealMonitor in Host side.
Any one is using RealMonitor from LPC2106 flash memory. Please give me
some solution for this.
Suggestions are always welcome.
-Srinivas.
2005-04-16 by ian48harry
> Hi,
me
> Regards,
> -Srinivas.
Srinivas:
Your ability to use RealMonitor depends on the silicon (OK in this
case), the compiler (does it generate the correct code) and the
debugger (not all support it) as well as your code.  What set-up do
you have?  Ashling's examples and their debugger work well.
Ian
