Lpc2000
CAN Test Mode
CAN Test Mode
2005-03-15 by peterburdine
I am trying to write some functions that will test if the CAN
controller is working properly.  I've figure out how to use CANMOD-STM
and CANCMR-SRR together to form an internal loopback.  What is
CANMOD-TM for?  Everytime I use it, I get an error.
Re: CAN Test Mode
2005-03-29 by peterburdine
I emailed this question to philips and this was their complete response:
"I'm not 100% certain but I beleive you need to connect the transmit
pin to the receive pin externally."
Not very helpful.
--Peter
Re: [lpc2000] Re: CAN Test Mode
2005-03-29 by Charles Manning
That's pretty useless advice.
The documentation states that the TM cause the state of the RX pin to be
copied to the TX pin.
To me this sounds like an "external loop-back" that you can use to cause the
received data to be looped back to the outside world without going through
the CAN controller. I guess this *could* be used for some things, but if you
have a standard 82C250/251-style CAN transeiver this will do nothing useful
since it will just cause the transceiver to latch up.
If the above is true, then I am not suprised that the CAN controller goes
silly when you invoke this mode.
For product level testing, what I do is hook the CAN lines to another device
in the test harness that has been configured for the same bit-rate: If the
device under test (DUT) can siuccessfully transmit a frame, then I know the
following happened:
i. DUT send data.
ii. Test harness sees the frame and sends Ack bit.
iii. DUT sees Ack bit.
Thus the whole rx/tx circuitry has been tested successfully.
> Not very helpful.
> --Peter
