Lpc2000
lpc2132 a/d converter
2005-03-16 by shaneprobinson2000
I am currently trying to use the 10 bit a/d converter available on
the lpc21xx devices.  I have not been able to get a full 10-bit
resolution out of the device and would appreciate any help.
In the datasheet it specifies a 4.5 MHz or less A/D clock.  I have
found that contrary to the datasheet I get more resolution if I turn
up the clock faster the 4.5 MHz.  If I turn it down (slower clock) I
get less bits.  This is somewhat counter intuitive as usually a
slower clock gives rise to a better signal? The input to the A/D
converter is a low impedance source (op amp directly coupled to
input pin).
Shane.
[lpc2000] 3 phase PWM
2005-03-17 by Marko Pavlin
Hello,
are there any code samples for generating 3 phase PWM? It will be used
for sensorless DC brushless motor with permanent magnets. I will use
LPC213x.
Marko
