Lpc2000
external interrupt edge sensitive don't work
2005-03-17 by Sébastien MARION (UMM)
Hello ,
  I use an LPC2210 and I would use two external interrupt in edge sensitive but it doesn't work.
  My hardware is : the same signal is connect to P0.15(EINT2) in falling edge sensitive , and P0.16(EINT0) in rising edge sensitive.
  My code is :
  #define REG(addr)              (*(volatile _uint32 *)(addr))
  #define REGSetBit(addr, mask)  (*(volatile _uint32 *)(addr) |= mask)
  #define REGClrBit(addr, mask)  (*(volatile _uint32 *)(addr) &= (~mask))
void EINT0Interrupt(void)    __attribute__ ((interrupt));
void EINT1Interrupt(void)    __attribute__ ((interrupt));
void EINT2Interrupt(void)    __attribute__ ((interrupt));
void EINT3Interrupt(void)    __attribute__ ((interrupt));
void InterruptEnable(_uint8 IntChannel)
  REG(VICIntEnable) = (1 << IntChannel);
void InitIntVectors(void)
  REG(VICIntSelect) = 0;                                 // set all interrupts as IRQs
  REG(VICDefVectAddr) = (_uint32)DefaultInterrupt;       // set ISR for non-vectored IRQs
  // Init Watchdog Interrupt Function
  REG(VICVectAddr0) = (_uint32)WatchdogInterrupt;        // set interrupt vector in 0
  REG(VICVectCntl0) = VICIrqChWDT | VICVectEnable;       // use it for Watchdog Interrupt
  // Init Timer0 Interrupt Function
  REG(VICVectAddr1) = (_uint32)Timer0Interrupt;          // set interrupt vector in 1
  REG(VICVectCntl1) = VICIrqChTimer0 | VICVectEnable;    // use it for Timer 0 Interrupt
  // Init Timer1 Interrupt Function
  REG(VICVectAddr2) = (_uint32)Timer1Interrupt;          // set interrupt vector in 2
  REG(VICVectCntl2) = VICIrqChTimer1 | VICVectEnable;    // use it for Timer 1 Interrupt
  // Init Uart0 Interrupt Function
  REG(VICVectAddr3) = (_uint32)Uart0Interrupt;           // set interrupt vector in 3
  REG(VICVectCntl3) = VICIrqChUart0 | VICVectEnable;     // use it for Uart 0 Interrupt
  // Init Uart1 Interrupt Function
  REG(VICVectAddr4) = (_uint32)Uart1Interrupt;           // set interrupt vector in 4
  REG(VICVectCntl4) = VICIrqChUart1 | VICVectEnable;     // use it for Uart 1 Interrupt
  // Init PWM0 Interrupt Function
  REG(VICVectAddr5) = (_uint32)PWM0Interrupt;            // set interrupt vector in 5
  REG(VICVectCntl5) = VICIrqChPWM0 | VICVectEnable;      // use it for PWM0 Interrupt
  // Init I2C Interrupt Function
  REG(VICVectAddr6) = (_uint32)I2CInterrupt;             // set interrupt vector in 6
  REG(VICVectCntl6) = VICIrqChI2C | VICVectEnable;       // use it for I2C Interrupt
  // Init SPI0 Interrupt Function
  REG(VICVectAddr7) = (_uint32)SPI0Interrupt;            // set interrupt vector in 7
  REG(VICVectCntl7) = VICIrqChSPI0 | VICVectEnable;      // use it for SPI0 Interrupt
  // Init SPI1 Interrupt Function
  REG(VICVectAddr8) = (_uint32)SPI1Interrupt;            // set interrupt vector in 8
  REG(VICVectCntl8) = VICIrqChSPI1 | VICVectEnable;      // use it for SPI1 Interrupt
  // Init PLL Interrupt Function
  REG(VICVectAddr9) = (_uint32)PLLInterrupt;             // set interrupt vector in 9
  REG(VICVectCntl9) = VICIrqChPLL | VICVectEnable;       // use it for PLL Interrupt
  // Init RTC Interrupt Function
  REG(VICVectAddr10) = (_uint32)RTCInterrupt;            // set interrupt vector in 10
  REG(VICVectCntl10) = VICIrqChRTC | VICVectEnable;      // use it for RTC Interrupt
  // Init EINT0 Interrupt Function
  REG(VICVectAddr11) = (_uint32)EINT0Interrupt;          // set interrupt vector in 11
  REG(VICVectCntl11) = VICIrqChEINT0 | VICVectEnable;    // use it for EINT0 Interrupt
  // Init EINT1 Interrupt Function
  REG(VICVectAddr12) = (_uint32)EINT1Interrupt;          // set interrupt vector in 12
  REG(VICVectCntl12) = VICIrqChEINT1 | VICVectEnable;    // use it for EINT1 Interrupt
  // Init EINT2 Interrupt Function
  REG(VICVectAddr13) = (_uint32)EINT2Interrupt;          // set interrupt vector in 13
  REG(VICVectCntl13) = VICIrqChEINT2 | VICVectEnable;    // use it for EINT2 Interrupt
  // Init EINT3 Interrupt Function
  REG(VICVectAddr14) = (_uint32)EINT3Interrupt;          // set interrupt vector in 14
  REG(VICVectCntl14) = VICIrqChEINT3 | VICVectEnable;    // use it for EINT3 Interrupt
  // Init AD Interrupt Function
  REG(VICVectAddr15) = (_uint32)ADInterrupt;             // set interrupt vector in 15
  REG(VICVectCntl15) = VICIrqChAD | VICVectEnable;     // use it for AD Interrupt
    _uint8 i;
    dLed.f->Set(LEDGREEN);
    for(i=0;i<10;i++){};
    dLed.f->Set(LEDRED);
  REG(EXTINT) = EXTINT0;
  // Acknowledge interrupt
  REG(VICVectAddr) = 0;
    _uint8 i;
  REG(EXTINT) = EXTINT2;
main(void) {
  InitIntVectors();
  // P0.15 et P0.16 is setting as EINT2 and EINT0
  _uint32 vpbdiv = REG(SYSCON_VPBDIV);
  vpbdiv = REG(SYSCON_VPBDIV); // 2210 Errata VPBDIV.1 work-aroud
  REG(SYSCON_VPBDIV) = 0;      // 2210 Errata EXTINT.1 work-aroud
  // Configure irq on rising edge
  REGSetBit(EXTMODE, EXTINT0); // edge sensitive
  REGSetBit(EXTPOLAR, EXTINT0);// edge positive
  REG(EXTINT) = EXTINT0;       // clear interrupt flag
  // Configure irq on falling edge
  REGSetBit(EXTMODE, EXTINT2); // edge sensitive
  REGClrBit(EXTPOLAR, EXTINT2);// edge negative
  REG(EXTINT) = EXTINT2;       // clear interrupt flag
  REG(SYSCON_VPBDIV) = vpbdiv;      // 2210 Errata EXTINT.1 work-aroud
  InterruptEnable(VICIrqChEINT2); // enable interrupt
  InterruptEnable(VICIrqChEINT0); // enable interrupt // Driver SFB : only edge negative needed
  while(1){};
AND THE RESULT IS :
signal in P0.15/16                     : ___                  _______
                                                      |__________|           |______--------
                                                        _   _  _  _   _   _____   _  _
Led level (high level is for green) : ____| |_| |_| |_| |_| |_|         |_| |_| |_------
INSTEAD OF
                                                           _________           _____
Led level (high level is for green) :  _____|               |______|         ------
if I doesn't active EINT2 it work well in falling edge ....
I dont understand why IRQ is always active even when there's no edge ....
thanks for advance for any idea why the code don't work.
and sorry for my very bad english.
Sebastien.
Re: external interrupt edge sensitive don't work
2005-03-17 by Mark Butcher
Hallo Sebastien
I didn't study your code because I'm not sure that it is the same
for the LPC210x (which I know) as for the LPC22xx (which I don't
know). However I did note this sentence towards the end which
reminded me of an experince I had:
"I dont understand why IRQ is always active even when there's no
edge ...."
These are my ideas
1. The interrupts are basically level sensitive and not specifically
falling edge sensitive.
2. If an interrupt routine is called due to the iRQ line going low
and doesn't do an action to cause the IRQ line to go high again [eg.
reading a register from an external peripheral device] it can NOT
clear the interrupt. It will reenter the IRQ routine as soon as it
leaves it.
[Detail: It is not possible to clear an interrup by using the
following code if the IRQ line stays low {EXTINT_bit.EINT2 = 1}
beacsue the level sensitive interrupt simply causes it to be set
again]
3. I wanted to have an interrupt on an input sensor and adopted the
following code (which I call "one-shot" interrupt code) - example
for IRQ2.
A: Prepare the "one shot" interrupt
  __disable_int();
  LPC210xInitExternalInterrupt2(fnEint2Interrupt);
  PINSEL0_bit.P0_15=0x2;  // Set pin function to EINT2
  EXTINT_bit.EINT2 = 1;   // try to clear any pending interrupt
  __enable_int();
void LPC210xInitExternalInterrupt2(void(*eint2_func)())
  eint2_function = eint2_func;     // Setup eint2 callback function.
  VICIntSelect &= ~VIC_EINT2_bit;  // IRQ on external int 2.
  VICVectAddr4 = (unsigned int)&ExternalInterrupt2;
  VICVectCntl4 = 0x20 | VIC_EINT2; // Enable vector interrupt.
  VICIntEnable = VIC_EINT2_bit;      // Enable EINT 2 interrupt.
B: When the IRQ occurs:
static void ExternalInterrupt2()   // IRQ 2 interrupt routine
  PINSEL0_bit.P0_15=0;    // Set pin function to normal input.
  (*eint2_function)();    // Execute interrupt callback function.
  EXTINT_bit.EINT2 = 1;   // Reset external interrupt flag.
You will see that the first thing which the IRQ routine does is to
set the IRQ line back to normal input. This allows the IRQ flag to
be reset even if the IRQ line remains low - hence the "One-shot"
property.
C: If another interrupt is required A: can be performed again.
Note that if the IRQ line is already at a low level the IRQ routine
will immediately be entered.
Maybe this was not exactly your problem but it may help.
Avec mes meilleurs salutations
Mark Butcher
www.mjbc.ch
Re: [lpc2000] Re: external interrupt edge sensitive don't work
2005-03-18 by Sébastien MARION (UMM)
Hello,
first, thanks for your answers.
I use the same user manual that the 210x serie.
>edge ...."
>These are my ideas
Why are they register for select edge sensitive if they work only in level sensitive ??? (EXTPOLAR register)
2005-03-19 by Mark Butcher
Hallo Sébastien
In my user manual (LPC2106/2105/2104 USER MANUAL) there is no
EXTPOLAR register so this must be specific to another processor type.
Mark Butcher
2005-03-21 by Sébastien MARION (UMM)
sorry it's the UM_LPC21XX_LPC22XX_2.pdf manual
and my problem concern just the EINT0 interrupt, I can't setting it without reason. (always low level sensitive)
Sebastien
  To: lpc2000@yahoogroups.com
  Sent: Saturday, March 19, 2005 1:57 AM
  Subject: [lpc2000] Re: external interrupt edge sensitive don't work
  Hallo Sébastien
  Mark Butcher
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
    http://groups.yahoo.com/group/lpc2000/
2005-03-30 by jbhoudry
I have the same problem, impossible to put 1 in EXTPOLAR and EXTMODE
for EINT0 (no problem for 1 to 3). I program all the recomendations
from philips :
Before writing to the EXTMODE and EXTPOLAR registers,
1> Write 0x0 to VPBDIV
2> Then write the desired value to EXTMODE or EXTPOLAR register.
3> Then write the same value to VPBDIV ( additional step)
4> Restore the VPBDIV to the previously saved value or simply write
   to the register again with the desired value.
I test on 2 LPC2294 the same, so now i use IT capture 0 timer 1
instead of EINT0 for my quad external uart!
--- In lpc2000@yahoogroups.com, Sébastien MARION (UMM)
> Sebastien
>   ----- Original Message -----
>   From: Mark Butcher
work
only
>   Hallo Sébastien
type.
>   Regards
>   Mark Butcher
>               ADVERTISEMENT
>   Yahoo! Groups Links
Service.
2005-03-31 by Bruce Paterson
> from philips :
Could Philips urgently confirm or not this EINT0 edge problem exists on
a LPC2124 ?
Just about to change a layout to use EINT0 in edge sensitive mode
(wasn't using it at all before) to WAKEup out of sleep mode, so I'm not
in a position to test this till it's all too late !!
Bruce
     /\\\/\\\/\\\    /   /      Bruce Paterson
    /  \\\ \\\ \\\  /   /    Senior Design Engineer
   /   /\\\/\\\/\\\/   /   8 Anzed Court, Mulgrave, Vic, 3170
  /   /  \\\ \\\ \\\  /  PO Box 4112, Mulgrave, Vic, 3170, Australia
/   /    \\\/\\\ \\\/   Ph: +61 3 8561 4232   Fax: +61 3 9560 9055
       Tele-IP Ltd.      Email: bruce@...    Icq: #32015991
                         WWW:   http://www.tele-ip.com       VK3TJN
WiFi
2005-03-31 by Curt Powell
Can anyone recommend WiFi (802.11b) chips that can be interfaced with LPC
2000 chips?
TIA,
Curt
Re: WiFi
2005-03-31 by charlesgrenz
Hi Curt,
 I recently used a Lantronix Wiport (WiFi). It is a can module that
solders to the board and gives you a standard serial connection up to
960K baud (or may be higher I not sure).
http://www.lantronix.com/device-networking/embedded-device-servers/wiport.html
regards,
Charles
with LPC
> 2000 chips?
> TIA,
> Curt
Re: [lpc2000] WiFi
2005-03-31 by Anton Erasmus
> LPC 2000 chips?
Not a LPC2000 solution, but if you want an ARM7 +Wi-fi in a very small
package you might look at the following:
http://linuxdevices.com/news/NS8386088053.html
   Anton Erasmus
A J Erasmus
2005-03-31 by philips_apps
Bruce,
I tried debugging the below code using the Keil MicroVision3
debugger.
	/* Configuring EXTMODE and EXTPOLAR    */
	VPBDIV=0x0;
	EXTMODE=0x1;
	VPBDIV=0x1;
	VPBDIV=0x0;
	EXTPOLAR=0x1;
	VPBDIV=0x1;
	VPBDIV=0x0;
It works fine on my end. Please dont single-step through these
instructions. You need to place a breakpoint at the instruction
following
        VPBDIV=0x0;
When this breakpoint is hit, on the Memory Window of the debugger,
EXTMODE and EXTPOLAR  should reflect 0x1
Best Regards,
Philips_apps
--- In lpc2000@yahoogroups.com, Bruce Paterson <bruce@t...> wrote:
EXTMODE
recomendations
> > from philips :
write
exists on
> a LPC2124 ?
not
> Cheers,
> Bruce
>        Tele-IP Ltd.      Email: bruce@t...    Icq: #32015991
Re: WiFi
2005-04-01 by Richard
We have used the Digi modules with no problems.
richard
> > LPC 2000 chips?
> Regards
>    Anton Erasmus
> A J Erasmus
RE: [lpc2000] WiFi
2005-04-01 by Paul Curtis
Hi Bill.
> You might want to have a look at the LPC-SBC2 board at
> http://www.theARMPatch.com It has a CompactFlash interface.
> A number of WiFi cards are available which use the
> CompactFlash though I would suggest one that uses the
> Intersil Prisim chipset.
> There was an article in Circuit Cellar a while back called
> WiFi SniFi which may also be of interest.  The code for it is
> available at http://www.beartreedesign.com/WiFi_SniFi.html
I've been using the EDTP AirDrop-A which also has a CF adapter and have
uIP running over 802.11b on an AVR with 4K of memory (and I don't use
anywhere near 4K).  Fred Eady's book which shows how to drive the PRISM
chipset in many of these CF cards will be published by Elsevier.  In
addition, his code works on a number of compilers for a couple of
architectures.  Of course, if you run Linux on the SBCm then you should
be able to use one of the OTS drivers.
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and (soon) MAXQ processors
Re: [lpc2000] WiFi
2005-04-01 by Bill Knight
You might want to have a look at the LPC-SBC2 board at http://www.theARMPatch.com
It has a CompactFlash interface.  A number of WiFi cards are available which use
the CompactFlash though I would suggest one that uses the Intersil Prisim chipset.
There was an article in Circuit Cellar a while back called WiFi SniFi which
may also be of interest.  The code for it is available at
-Bill Knight
R O SoftWare &
> LPC 2000 chips?
2005-04-01 by Sébastien MARION (UMM)
hi,
  I make the same things with pathfinder and EXTMODE are correct BUT without effect on the behaviour of EINT0 always on low level detection mode ....
  I note that EXTMODE and EXTPOLAR never chane the behaviour of EINT0 !!! (same code with EINT2 work very fine)
Sébastien
  To: lpc2000@...m
  Sent: Thursday, March 31, 2005 11:58 PM
  Bruce,
  debugger.
        VPBDIV=0x0;
        EXTMODE=0x1;
        VPBDIV=0x1;
        VPBDIV=0x0;
        EXTPOLAR=0x1;
        VPBDIV=0x1;
        VPBDIV=0x0;
  following
          VPBDIV=0x0;
  Best Regards,
  Philips_apps
  EXTMODE
  recomendations
  > > from philips :
  write
  exists on
  > a LPC2124 ?
  not
  > Cheers,
  > Bruce
  Yahoo! Groups Links
2005-04-01 by jbhoudry
I make the same things, whith Phytec board LPC2294, Isystem Ione and
Iar compiler, work fine for EINT1-3 and always 0 for EINT0!
JBH
> hi,
detection mode ....
> Regards,
> Sébastien
>   From: philips_apps
work
>   Bruce,
>   debugger.
>         VPBDIV=0x0;
>         EXTMODE=0x1;
>         VPBDIV=0x1;
>         VPBDIV=0x0;
>         EXTPOLAR=0x1;
>         VPBDIV=0x1;
>         VPBDIV=0x0;
>   following
>           VPBDIV=0x0;
debugger,
>   Best Regards,
>   Philips_apps
>   EXTMODE
>   recomendations
>   > > from philips :
register.
>   write
1
>   exists on
>   > a LPC2124 ?
mode
I'm
>   not
>   > Cheers,
>   > Bruce
Australia
9055
VK3TJN
>   Yahoo! Groups Links
Service.
Re: WiFi
2005-04-01 by Gus
wiport works fine at $140!! ALFATxp is better/faster with FAT file
system for HTTP. It is not ready yet but we can hook you up with
early adoption program.
http://www.ghielectronics.com/ALFATxp.htm
Gus
--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@s...>
wrote:
> Hi Curt,
to
servers/wiport.html
> regards,
> Charles
> with LPC
> > 2000 chips?
> > TIA,
> > Curt
