Is it correct, that the FullCANmode is not yet operational? When will
it be fixed? What will be the expected performance advantage of the
FullCANmode compared to the BasicCANmode?
Thanks, Klaus
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
wrote:
> Andreas,
> you are right and you are right. It seems somebody mixed up FallCAN
> and extended identifiers and 29-bit identifiers are supported. For
> sure the LPC229x and as well the single chip versions 21x9, 2194
they
> are all using the same CAN interface and they all support 29-bit
> indentifiers. The filtering works perfectly for extended
> identifiers.
> The mix up might be from the fact that even when the FullCAN mode
> will be fixed, the FullCAN mode does not support 29-bit
identifiers,
> only 11-bit.
> A little bit more information about the difference between the
> FullCAN mode and let's call it the gateway mode assuming a fully
> functional FullCAN.
> If a message is received in FullCAN mode, it is transfered by an
> internal statemachine (let's call it CAN-DMA) into the assigned
> message object buffer. The other feature that is often assigned to
> FullCAN, the filtering can also (even better) be done in the
gateway
> mode.
> In the gateway mode, the CAN implementation offers up to 1024!!
> filters for standard frames (11-bit identifiers) or up to 512
filters
> for extended (29-bit) identifiers. This is MUCH more than any
> existing FullCAN implementation would allow.
> Summary: you can filter for 29-bit, the filtering options in
gateway
> mode outperform any existing FullCAN implementation but your
software
> has to deal with the (filtered) messages you receive and move them
to
> their final destination in memory otherwise they can be overwritten
> by new incoming messages.
> Hope this helps you and does not confuse too many of the others not
> so familiar with CAN :-)
> Robert
> --- In lpc2000@yahoogroups.com, "alipowsky" <a.lipowsky@g...> wrote:
> > The following statement was given as response to a question via
> > Philips online support:
> > "The attached errata lists the known bugs in the LPC2119. Note
that
> > FullCAN mode is not operative. Hence the CAN module on our ARM7
> > doesn't currently support 29 bit identifier because Full CAN is
> > inoperative."
> > Did there somebody mix up the terms FULL-CAM and 29 Bit
> identifier's??
> > Of course we use 29 Bit identifier in our actual LPC2292 project.
> > But we found a problem with global acceptance filtering:
> > We have a master sending frames to severall slaves and the slave
> > respond to this frames.
> > To reduce the interrupt overhead in the slaves, we use acceptance
> > filtering to filter all master frames, this is possible because we
> > defined one Identifier bit to be a direction Bit (0: Master =>
> Slave,
> > 1: Slave => Master)
> > Before we used exceptance filtering we got overflow errors,
because
> > every slave node also got the answer of all the other slave nodes.
> > When we use acceptance filtering we don't get this overflow
errors,
> > but now it happens that our LPC-2292 Node stops to generate
> > CAN-Interrupts at all !
> > Did anybody made comparable experiences with the CAN-Interrupts.
> > Andreas Lipowsky
