Lpc2000
Reg: Timer Interrupt Problems
2005-04-01 by rockraj_2003
Hello Friends,
I am a silent member of this groups.
Now i am doing a project.
In my project, i want to use 2 Timers.
The TIMER1 is setting in the main function it's working perfectly.
But when i call the same in the function Check,it's not responding.
After the function Check i put the arm in the idle mode.
But its not repeating the loop.
I am using IAR Embedded WorkBench only.
The code is as follows:
#include "timer.h"
#include "lpc210x.h"
#include <inarm.h>
#include <iolpc210x.h>
#include <arm_interrupt.h>
#define BAUDRATE 38400
#define BAUDRATEDIVISOR (PCLKFREQ/(BAUDRATE*16))
#define VIC_TIMER0_bit (1 << VIC_TIMER0)
#define VIC_TIMER1_bit (1 << VIC_TIMER1)
static void (*timer_function)();
static void (*timer_function_ONE)();
static short Refr_Rate1 = 990
S8 MA_Stop_TIMER( U8 Channel );
static void TimerInterruptONE()
MA_PutString_UART1("ERROR");
   T1IR = 0xff;
static void TimerInterrupt()
	 MA_PutString_UART1("OK");
T0IR = 0xff;
__irq __nested __arm void irq_handler(void)
  void (*interrupt_function)();
  unsigned int vector;
  vector = VICVectAddr;
  interrupt_function = (void(*)())vector;
  VICVectAddr = 0;
void LPC210xSystemInit()
  MEMMAP = 2;
void LPC210xInitVIC()
  VICProtection = 0;
  VICIntEnClear = 0xffffffbf;
  VICDefVectAddr = (unsigned int)&DefDummyInterrupt;
void LPC210xInitTimerInterruptONE(void(*timer_func_ONE)())
  timer_function_ONE = timer_func_ONE;
  VICIntSelect &= ~VIC_TIMER1_bit;
  VICVectAddr6 = (unsigned int)&TimerInterruptONE;
  VICVectCntl6 = 0x20 | VIC_TIMER1;
  VICIntEnable = VIC_TIMER1_bit;
void LPC210xInitTimerInterrupt(void(*timer_func)())
  // Setup timer callback function.
  timer_function = timer_func;
  VICIntSelect &= ~VIC_TIMER0_bit; // IRQ on timer 0 line.
  VICVectAddr1 = (unsigned int)&TimerInterrupt;
  VICVectCntl1 = 0x20 | VIC_TIMER0; // Enable vector interrupt for
timer 0.
  VICIntEnable = VIC_TIMER0_bit;    // Enable timer 0 interrupt.
void Set_Timer()
   __disable_interrupt();
   LPC210xSystemInit();
   LPC210xInitTimer();
   LPC210xInitVIC();
   LPC210xInitTimerInterrupt(TimerBeat);
   __enable_interrupt();
   LPC210xStartTimer();
void Set_Timer_ONE()
   LPC210xInitTimerONE();
   LPC210xInitVIC();
   LPC210xInitTimerInterruptONE(TimerBeat);
   LPC210xStartTimerONE();
void LPC210xInitTimerONE()
  T1TCR = 0;
  T1PC = 0;
  T1MR0 = Refr_Rate1;
  T1MCR = 3;
  T1CCR = 0;
  T1EMR = 0;
void LPC210xInitTimer()
  T0TCR = 0;
T0PC = 0;
  T0MR0 = Refresh_Rate;
  T0MCR = 3;
  T0CCR = 0;
  T0EMR = 0;
void LPC210xStartTimerONE()
  T1TCR = 1; // Enable timer 1.
void LPC210xStartTimer()
  T0TCR = 1; // Enable timer 0.
void check()
        Refr_Rate1 = 45 * Refr_Rate1;
        Set_Timer_ONE();
        PCONP = 0X004;
        PCON = 0x01;
        PCONP = 0x01E;
        MA_Stop_TIMER(1);
        Refr_Rate1 = 900;
	MA_PutString_UART1("PROGRAMMED CHECKED");
    ENTER_MA_STOP_TIMER;
    switch( Channel )
    case 0:
        T0TCR_bit.CE = 0;
        break;
    case 1:
        T1TCR_bit.CE = 0;
        break;
    default:
        EXIT_MA_STOP_TIMER;
        return MA_ERROR;
    EXIT_MA_STOP_TIMER;
   return MA_OK;
} /* MA_Stop_TIMER */
void main(void)
        short ON=1;
        short FLAG_SETN;
        short i;
START:  MA_Reset_SCB();
	MA_Reset_PCB();
        T0MCR = 0;
        T1MCR = 0;
      	MA_Init_GPIO();
        IOCLR = 0x00000010;
        Sleep(400000);
        Set_Timer_ONE();
        PCONP = 0X004;
        PCON = 0x01;
        PCONP = 0x01E;
        MA_Stop_TIMER(1);
        Refr_Rate1 = 900;
        MA_Init_UART1();
	MA_Reset_UART1();
        MA_Init_UART0();
        MA_Reset_UART0();
 	IOCLR = 0x00000010;
        Sleep(400000);
	IOSET = ((unsigned long)1) << 4;
	IOSET = ((unsigned long)1) << 2;
	check();
	PCON = 0x01;
        else goto START;
Kindly clarify my doubt.
with regards,
Rajendra R
