Lpc2000
ADC Test Setting
ADC Test Setting
2005-04-05 by peterburdine
Can anyone please explain the test settings for the ADC on the LPC2xxx?
00=Normal Mode - Ok, I know this one
01=Digital Test Mode - Does this mean that you set the output of the
pin to be 1 or 0 and then read 0x3FF or 0x000 from the ADC?
10=DAC Test Mode - ?
11=Simple Conversion Test Mode - ?
Peter
Re: ADC Test Setting
2005-04-06 by peterburdine
Apparently, Philips doesn't want us to test anything ourselves.  I
sent them this question and here is their response:
"The test mode bits you refer to are for factory use only and will be
removed from the manual when we publish the next revision.  Leave
these bits as 00."
--Peter
> Thanks,
> Peter
