Lpc2000
Questions on LPC Flash Programming Routines
2005-04-08 by Bruce Paterson
Bill Knight wrote:
> I just uploaded a set of LPC flash programming routines to the files area
> on Yahoo.  They were written for gcc and support both ARM and Thumb modes
> of operation.  Hopefully, they will prove useful to the group.
Bill,
Just been having a look at your routines as I need to do some IAP now
myself.
I have a few questions to you/the group if you don't mind:
1/ I notice you expect CMD_SUCCESS, never BUSY back from calling iap.
This implies to me the iap routines always execute to completion before
returning (this conficts with another posting to this group which showed
a for(;;) loop waiting for non-BUSY return). Confused !
2/ If the iap routines don't return till all is done, what happens to
the watchdog ? The watchdog cannot be disabled once started, so do
a) the iap routines feed the watchdog internally (philips question) ?
b) we need to reboot with watchdog disabled in order to do IAP ?
3/ I notice you prepare all sectors for write every interation of your
writing loop. Is this just for easier coding ?
4/ In what cases would memmap be anything other than user code in
practice ? (I notice you save and restore).
Bruce
     /\\\/\\\/\\\    /   /      Bruce Paterson
    /  \\\ \\\ \\\  /   /    Senior Design Engineer
   /   /\\\/\\\/\\\/   /   8 Anzed Court, Mulgrave, Vic, 3170
  /   /  \\\ \\\ \\\  /  PO Box 4112, Mulgrave, Vic, 3170, Australia
/   /    \\\/\\\ \\\/   Ph: +61 3 8561 4232   Fax: +61 3 9560 9055
       Tele-IP Ltd.      Email: bruce@...    Icq: #32015991
                         WWW:   http://www.tele-ip.com       VK3TJN
Re: [lpc2000] Questions on LPC Flash Programming Routines
....and one more question after further study....
5/ I notice you copy from the flash into the temporary buffer if we're
not 512byte aligned, or for the final fragment of size < 512.
You also say:
  *  NOTE: When programming data into a sector that is already partially
  *  programmed, all new data MUST be programmed into previously
  *  unprogrammed 16-byte (128-bit) [Ed: Assume 512-byte now] blocks.
The statement implies you cannot write a block unless the flash has been
previously erased => all 0's or FF's. So why bother copying these (dst)
back into the temporary buffer prior to copying the partial (src) over
the top ?
May as well dispense with the temporary buffer and just back the (src)
pointer back into whatever crap is in RAM there and write that into the
512-aligned-dst (similar with the far end).
Seems to me the only way to achieve what I think you're trying to do is
to make a whole segment copy prior to erase, and then write overwrite
that huge (8k or more) buffer with (src), then program that. Have I got
misunderstood something here ?
Bruce
This email and any files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom
they are addressed. If you have received this email in error please
notify the system manager.
2005-04-08 by Bill Knight
Answers interspersed
-Bill
Bill,
myself.
*** The code simply returns the result whenever it is not CMD_SUCCESS or
when done.  A test for BUSY could be added to flashWrite() with a limit
to the number of tries.  So far, I have not found this to be a problem
but YMMV.
*** I'll leave the answer for this one to the Philis Apps guys.
*** Caught me.  Because the translation from address to sector number
is different between various LPC parts, I chose to do it the simple
way.
*** Not exactly.  The interrupt vectors could have been remapped
to RAM.
Bruce
2005-04-08 by Robert Adsett
>You also say:
>the top ?
Semantics I believe.  Cannot in this case means not that the flash won't
get written, but that the value that results from the write won't match the
actual value written unless it is an exact match for what was already in
the flash.  In addition to the corruption due to previously high bit being
programmed low the internal EDC code will be wrong for that 16 byte block
now.  Basically once a 16 byte block has been modified no further
successful changes can be made to it, any modifications will result in
corrupted memory.
Oh, BTW, erasing flash results in all high bits (0xFF).
You can (must?) program a 512byte chunk at once, but you must take care to
preserve anything already written.  This is no different than any other
flash memory.  They only differ in the details of what may be written and
in what size of chunk.  Many allow any high bit to be programmed low, the
LPC error correction circuitry treats 16byte block as a single location
that must be dealt with as a unit and only programmed from all 1's once
between erases.  Erase, on the other hand, uses larger chunk sizes.  8K I
think is the smallest.
I hope that clears things up a bit.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-04-11 by Bruce Paterson
>>You also say:
>>the top ?
OK on that. Only the first write can change it. Subsequent writes to the
same area must re-write the same data.
Thought it might :)
Ahhh I get it. The routine lets you write say a single byte at a time.
You can only ever write any particular byte once per erase, but each
byte write is implemented by writing the same 512bytes every time, but
with 1 new byte changed each time.  I was only thinking of >512byte
(misaligned) writes before. Doh!
...BUT, the minimum size you can *actually* write is 16bytes (on a 16
byte boundary?) rather than 1 byte, due to the LPC error correction, so
we should probably add this restriction to the routine.
In fact, the routine could also check for double writes by ensuring all
_new_ bytes to be added in a call are all to be written over FF's.
I can see how this could work for direct translation of say incoming hex
records to flash (as long as |16byte| in length), but don't think it
would help much for 'non-volatile' ram situations in practice because
the ram case would need to remember across the erase anyway.
Yup, Ta!
Bruce
2005-04-13 by Bruce Paterson
Robert ?
Bruce
