LPC2138+User Manual
2005-04-21 by sudip nag
Hi, I do not find LPC2138 User's Manual after consecutive searches in Philips website. Is it really posted separately. Sudip Nag Yahoo! India Matrimony: Find your life partneronline. [Non-text portions of this message have been removed]
2005-04-21 by Digital Systems, Partner
I am working on a battery power instrument and wants to know current consumption of LPC2132. Can somebody help? Vimal Amin On 4/21/05, sudip nag <sudipnag1@...> wrote: > > > Hi, > > I do not find LPC2138 User's Manual after consecutive searches in Philips website. Is it really posted separately. > > Sudip Nag > > Yahoo! India Matrimony: Find your life partneronline. > > [Non-text portions of this message have been removed] > > Yahoo! Groups Links > > > > > -- Vimal Amin Digital Systems, Partner 204 Tapo Comm. Center RamMandir Road Goregaon (W) Mumbai 400104 India Phone : 91 22 2875 4218 Fax : 2874 2093
2005-04-21 by dlmassey2000
--- In lpc2000@yahoogroups.com, sudip nag <sudipnag1@y...> wrote: > > > > Hi, > > I do not find LPC2138 User's Manual after consecutive searches in Philips website. Is it really posted separately. > > Sudip Nag > > > Yahoo! India Matrimony: Find your life partneronline. > > [Non-text portions of this message have been removed] I found it here www.keil.com/dd/docs/datashts/philips/lpc213x_um.pdf Regards Dennis
2005-04-21 by lpc2100_fan
It is posted in this forum in the files section Bob --- In lpc2000@yahoogroups.com, "dlmassey2000" <dlmassey1@v...> wrote:
> > --- In lpc2000@yahoogroups.com, sudip nag <sudipnag1@y...> wrote: > > > > > > > > Hi, > > > > I do not find LPC2138 User's Manual after consecutive searches in > Philips website. Is it really posted separately. > > > > Sudip Nag > > > > > > Yahoo! India Matrimony: Find your life partneronline. > > > > [Non-text portions of this message have been removed] > > I found it here www.keil.com/dd/docs/datashts/philips/lpc213x_um.pdf > > Regards > Dennis
2005-04-22 by Robert Wood
Hi folks, I'm setting up comms between an LPC2194 and an FTDI USB chip. It would appear that the CTS of the LPC can be connected to the RTS of the FTDI device as the FTDI device sets its RTS high when its receive buffer only has 32bytes of space left in it. It can thus tell the LPC to stop transmitting and it seems that taking the CTS line high on the LPC will, indeed, stop the LPC from sending data out. So, it looks like the RTS of the FTDI chip is really a ready to receive signal. However, it looks like the RTS on the LPC is not quite the same. It seems that it really is a request to send, rather than a ready to receive signal. The closest pin I can find would seem to be DTR, but I don't think it's the same thing at all. Do I understand correctly? Does the LPC simply not have a pin that can drive an external device to tell that external device that it [the external device] may send data into the UART of the LPC? Hope this makes sense, the terminology is rather confusing! ;-) Rob - who's never done hardware flow control before! :~)
2005-04-22 by Robert Adsett
At 04:47 PM 4/22/05 +0100, Robert Wood wrote: >I'm setting up comms between an LPC2194 and an FTDI USB chip. It would >appear that the CTS of the LPC can be connected to the RTS of the FTDI >device as the FTDI device sets its RTS high when its receive buffer only >has 32bytes of space left in it. It can thus tell the LPC to stop >transmitting and it seems that taking the CTS line high on the LPC will, >indeed, stop the LPC from sending data out. > >So, it looks like the RTS of the FTDI chip is really a ready to receive >signal. > >However, it looks like the RTS on the LPC is not quite the same. It >seems that it really is a request to send, rather than a ready to >receive signal. The closest pin I can find would seem to be DTR, but I >don't think it's the same thing at all. > >Do I understand correctly? Does the LPC simply not have a pin that can >drive an external device to tell that external device that it [the >external device] may send data into the UART of the LPC? I think you are expecting too much of the UART. As I recall the pins are assigned there function by convention only. You can make them mean anything you want them to. They are controlled strictly by software not by the HW. As a side note, strictly speaking the pins are not defined as flow control pins. They are used that way frequently though and the 232 interface long ago lost its connection to the standard definition. Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
>> I think you are expecting too much of the UART. As I recall the pins are assigned there function by convention only. You can make them mean anything you want them to. They are controlled strictly by software not by the HW. << Ah, OK. Thanks for the advice. :-) Seems pretty odd to name them that if they don't really carry out that function. Hey ho... Cheers, Rob
At 05:00 PM 4/22/05 +0100, Robert Wood wrote: > >> I think you are expecting too much of the UART. As I recall the >pins are assigned there function by convention only. You can make them >mean >anything you want them to. They are controlled strictly by software not >by the HW. << > >Ah, OK. > >Thanks for the advice. :-) > >Seems pretty odd to name them that if they don't really carry out that >function. Hey ho... It's more common than you might think. The most infamous example that I know of is the 8255. The data sheets stated that the chip provided handshaking. It was only by careful reading of the datasheet, usually when trying to get it to do the handshaking, that it became obvious that it didn't provide handshaking at all but only bits whose direction could be set. Some of the second source manufacturers eventually changed the documentation but I don't think Intel ever did. Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
2005-04-22 by lpcarmed
The good thing you can get a modem status change interupt when CTS changes. --- In lpc2000@yahoogroups.com, Robert Wood <robert.wood@a...> wrote: > >> I think you are expecting too much of the UART. As I recall the > pins are assigned there function by convention only. You can make them > mean > anything you want them to. They are controlled strictly by software not
> by the HW. << > > Ah, OK. > > Thanks for the advice. :-) > > Seems pretty odd to name them that if they don't really carry out that > function. Hey ho... > > Cheers, > > Rob
2005-04-23 by bobtransformer
I wish there were a way to re-define some of these dedicated pin functions... I can't seem to find more than 2 PWM outputs and have to give up A/D inputs if I want to use both UARTs. boB --- In lpc2000@yahoogroups.com, Robert Wood <robert.wood@a...> wrote: > >> I think you are expecting too much of the UART. As I recall the > pins are assigned there function by convention only. You can make them > mean > anything you want them to. They are controlled strictly by software not > by the HW. << > > Ah, OK. > > Thanks for the advice. :-) > > Seems pretty odd to name them that if they don't really carry out that
