Anyone using Forth on LPC21xx?
2005-04-26 by Peter Jakacki
I've been writing a token threaded Forth for the LPC21xx and just
wondering if anybody else has been using Forth on this processor and
what are their experiences?
It certainly has let me fully explore the chip and push the peripherals
interactively. Some screen dumps are shown for reference below.
*Peter*
Sieve of Eratosthenes
PJarmOS IV - 1.0
Copyright 2005 Peter Jakacki (peter@...)
Target: ACP #1 - LPC210X 32bit ARM7 - 4293984018 1.52
8190d CONSTANT *SIZE
40001000h CONSTANT *FLAGS
: SIEVE
0 MS! DECIMAL 0A 0
DO *FLAGS *SIZE 1 FILL
0 *SIZE 0
DO I *FLAGS + C@
IF 3 I + I + DUP I + *SIZE <
IF *SIZE *FLAGS + OVER I + *FLAGS +
DO 0 I C! DUP +LOOP
THEN
DROP 1+
THEN
LOOP
CR . ." Primes"
LOOP
CR MS@ .
SIEVE
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
1899 Primes
673 ok
ok
SEE SIEVE
4000070C: 00 0
4000070D: AF MS!
4000070E: 9B DECIMAL
4000070F: 0A 0A
40000710: 00 0
40000711: 11 (DO)
40000712: FE 0029 *FLAGS
40000715: FE 0044 *SIZE
40000718: 01 1
40000719: 24 FILL
4000071A: 00 0
4000071B: FE 004A *SIZE
4000071E: 00 0
4000071F: 11 (DO)
40000720: 14 I
40000721: FE 0038 *FLAGS
40000724: 48 +
40000725: 21 C@
40000726: F3 26 if
40000728: 03 3
40000729: 14 I
4000072A: 48 +
4000072B: 14 I
4000072C: 48 +
4000072D: 3A DUP
4000072E: 14 I
4000072F: 48 +
40000730: FE 005F *SIZE
40000733: 65 <
40000734: F3 16 if
40000736: FE 0065 *SIZE
40000739: FE 0050 *FLAGS
4000073C: 48 +
4000073D: 3D OVER
4000073E: 14 I
4000073F: 48 +
40000740: FE 0057 *FLAGS
40000743: 48 +
40000744: 11 (DO)
40000745: 00 0
40000746: 14 I
40000747: 20 C!
40000748: 3A DUP
40000749: F8 FB (+LOOP)
4000074B: 41 DROP
4000074C: 4A 1+
4000074D: F7 D2 (LOOP)
4000074F: 78 CR
40000750: C8 .
40000751: E8 str (.") Primes
4000075A: F7 B7 (LOOP)
4000075C: 78 CR
4000075D: AE MS@
4000075E: C8 .
4000075F: FF EXIT
+WORDS
6340 ABORT 6328 QUIT 62E0 ?LINK
62AC LINK, 622C FINIS 6204 SOURCE
61E4 EVAL 61A4 UPPER 6150 $INTERPRET
60B4 NUMBER 6018 DIGIT? 6000 FORTH
5FE4 PRESET 5F48 $COMPILE 5F1C LITERAL
5F00 COMPILE 5EE4 ; 5ED0 OVERT
5EB4 : 5E94 CREATE 5E7C VARIABLE
5E58 DS32 5E3C VALIGN 5E24 DS8
5E04 CONSTANT 5DE8 HEADER 5DC0 COMPO
5DA8 IMMEDIATE 5D78 WORD, 5D2C $,
5D10 ] 5CF4 [ 5CE0 $"
5CCC ." 5CB8 $," 5CA4 (.")
5C90 $" 5C78 do$ 5C54 SILENT
5C3C ECHO 5C18 /* 5C04 (
5BF0 \ 5BD8 QUERY 5B94 ACCEPT
5B60 KTAP 5B40 TAP 5B00 LEN
5AD4 TYPE 5AC0 ? 5AA0 U.N
5A80 . 5A6C U. 5A54 U.R
5A38 .R 5A28 D. 5A14 D.R
59F0 NSTR 59D4 STR 59BC #>
59A8 SIGN 5990 #S 597C #
5968 HOLD 5950 <# 5938 DIGIT
5920 ' 5900 PARSE 58A8 parse
5830 FIND 5800 NFA>CFA 57B8 CFA>TKN
5798 CFA>NFA 5774 NFA+ 5760 HERE
5744 C, 5724 W, 56F4 ,
56E4 ALLOT 56CC RING 56BC ok
56B0 OK 569C PROMPT 5624 .VER
5604 DU 55D8 WDUMP 5580 DUMP
5530 .S 54F4 .LS 54C0 .H
54AC .WORD 5490 .BYTE 545C WORDS
53E8 +WORDS 53C4 AWORDS 53AC CR
5394 SPACES 5380 SPACE 5354 TERMINAL
5334 @XY 531C @Y 5308 @X
52EC HBAR 52C8 VBAR 529C RECT
527C RFILL 5260 HLINE 5244 VLINE
5228 PLOT 4FAC EMITV 4F94 VGA
4F7C CLRSCR 4F3C CXY 4F24 BG!
4ED4 FG! 4EB4 VIDEO 4DAC SD
4D88 SU 4D74 VS 4D50 DISPLAY
4D28 C/L 4D10 Y* 4CFC X*
4CE0 @VGA 40E0 SPI@ 406C SPI!
404C SPI 4038 !SPI 3F48 COP
3F00 FLASH 3E8C BACKUP 3E28 ERASEF
3DFC PROGRAM 3D80 PROGRAM1 3D2C .CPU
3CF8 IAPBUF 3C84 IAP 3C70 CPSR!
3C58 CPSR@ 3BB0 TIMEOUT? 3B90 TIMER
3B6C MS 3B5C MS! 3B44 MS@
3AC4 !TIMER 3AB0 TX1LED 3A9C RX1LED
3A88 TX0LED 3A74 RX0LED 3A50 STATLED
3A24 BAUD 39F4 BAUD1 39C0 BAUD0
3968 PLL! 379C RX1@ 3784 RX1@
3760 TX1! 3718 COM1 3460 RX0@
343C TX0! 33E4 COM0 31F8 AUTOBAUD
31B0 FLUSH 3190 CONNECT 3170 CLS
3158 HOME 3140 PRTSCN 3128 BG
3114 FG 30F0 REVERSE 30D4 BLINK
30BC UNDERLINE 30A0 DIM 3088 BOLD
3070 PLAIN 3038 NUL 3028 CON
300C KEY 2FF8 KEY? 2FE4 CMD
2FD0 EMIT 2FB4 MASK 2FA0 TEST
2F84 BIT 2F6C BCLR 2F54 BSET
2F40 b 2F20 C+! 2EFC +!
2ED0 CMOVE 2EBC ERASE 2E90 FILL
2E54 NA! 2E1C NA@ 2E00 H!
2DE0 H@ 2DCC C@ 2DB4 C!
2D98 D@ 2D78 D! 2D64 @
2D4C ! 2D38 ENDCASE 2D1C CASE
2CF0 case 2CD8 NEXT 2CC4 FOR
2C9C (DONEXT) 2C84 BOUNDS 2C6C LEAVE
2C54 +LOOP 2C3C LOOP 2C28 DO
2C14 J 2C00 I 2BEC (+LOOP)
2BA8 (LOOP) 2B88 (DO) 2B6C @EXECUTE
2B4C EXECUTE 2B28 CALL 2B0C AFT
2AF4 WHILE 2AD8 REPEAT 2AC0 AGAIN
2AA8 UNTIL 2A94 BEGIN 2A7C ELSE
2A64 AHEAD 2A48 THEN 2A30 IF
2A0C ?BRANCH 29E0 if 29CC else
299C until 297C again 2964 BRANCH
2920 SCALE 290C S>D 28F4 DABS
28D8 ABS 28AC DNEGATE 288C NEGATE
2874 WITHIN 285C MIN 2844 MAX
2814 = 27FC U< 27EC >
27C8 < 27A0 0< 2790 0<>
277C 0= 276C <> 2758 SPLIT
273C ROR 2720 SHL 2704 SHR
26EC 2* 26D8 2/ 26C8 /
26B8 MOD 26A0 /MOD 264C U/
2634 M/DMOD 2608 M/MOD 25C8 UM/MOD
25A4 M* 2584 UM* 2564 *
2548 U* 2520 UM+ 2508 1-
24F4 1+ 24DC - 24C4 +
24AC NOT 2490 XOR 2474 OR
245C AND 243C REGS 241C REG
2400 ?STACK 23EC 2DROP 23D4 DROP
23B0 ROT 2380 2SWAP 2360 SWAP
2340 2OVER 2328 OVER 2308 2DUP
22E8 ?DUP 22D0 DUP 22C0 NOP
2294 PLACE 2270 PICK 2250 DEPTH
2234 L> 2224 >L 2210 R@
21FC R> 21EC >R 21D0 !LP
21B0 !RP 219C RP! 2184 RP@
2164 !SP 2150 SP! 2138 SP@
2120 COLD 210C d 20FC h
20E8 HEX 20D4 DECIMAL 20BC BINARY
20A0 ALIGNED 207C CELLS 2064 CELL-
204C CELL+ 2018 LIT32 1FF8 LIT16
1FE0 LIT8 1FC0 (.") 1FAC WDTV
1F98 WDFEED 1F84 WDTC 1F70 WDMOD
1F5C WD 1F4C PREFRAC 1F34 PREINT
1F20 ALYEAR 1F0C ALMON 1EF8 ALDOY
1EE4 ALDOW 1ED0 ALDOM 1EBC ALHOUR
1EA8 ALMIN 1E94 ALSEC 1E80 YEAR
1E6C MONTH 1E58 DOY 1E44 DOW
1E30 DOM 1E1C HOUR 1E08 MINS
1DF4 SEC 1DE0 CTIME2 1DCC CTIME1
1DB8 CTIME0 1DA4 AMR 1D90 CIIR
1D7C CCR 1D68 CTC 1D54 ILR
1D40 RTC 1D2C SPINT 1D18 SPTOR
1D04 SPTSR 1CF0 SPTCR 1CDC SPCCR
1CC8 SPDR 1CB4 SPSR 1CA0 SPCR
1C8C SPI 1C78 I2CONCLR 1C60 I2SCLL
1C4C I2SCLH 1C38 I2ADR 1C24 I2DAT
1C10 I2STAT 1BFC I2CONSET 1BE4 I2C
1BD0 U1DLM 1BBC U1DLL 1BA8 U1SCR
1B94 U1MSR 1B80 U1LSR 1B6C U1MCR
1B58 U1LCR 1B44 U1FCR 1B30 U1IIR
1B1C U1IER 1B08 U1THR 1AF4 U1RBR
1AE0 U1 1AD0 U0DLM 1ABC U0DLL
1AA8 U0SCR 1A94 U0MSR 1A80 U0LSR
1A6C U0MCR 1A58 U0LCR 1A44 U0FCR
1A30 U0IIR 1A1C U0IER 1A08 U0THR
19F4 U0RBR 19E0 U0 19D0 PWMLER
19BC PWMPCR 19A8 PWMEMR 1994 PWMCR3
1980 PWMCR2 196C PWMCR1 1958 PWMCR0
1944 PWMCCR 1930 PWMMR6 191C PWMMR5
1908 PWMMR4 18F4 PWMMR3 18E0 PWMMR2
18CC PWMMR1 18B8 PWMMR0 18A4 PWMMCR
1890 PWMPC 187C PWMPR 1868 PWMTC
1854 PWMTCR 1840 PWMIR 182C PWM
1818 T1EMR 1804 T1CR3 17F0 T1CR2
17DC T1CR1 17C8 T1CR0 17B4 T1CCR
17A0 T1MR3 178C T1MR2 1778 T1MR1
1764 T1MR0 1750 T1MCR 173C T1PC
1728 T1PR 1714 T1TC 1700 T1TCR
16EC T1IR 16D8 T1 16C8 T0EMR
16B4 T0CR3 16A0 T0CR2 168C T0CR1
1678 T0CR0 1664 T0CCR 1650 T0MR3
163C T0MR2 1628 T0MR1 1614 T0MR0
1600 T0MCR 15EC T0PC 15D8 T0PR
15C4 T0TC 15B0 T0TCR 159C T0IR
1588 T0 1578 EXTWAKE 1560 EXTINT
154C PCONP 1538 PCON 1524 VPBDIV
1510 VPB 14FC PLLFEED 14E4 PLLSTAT
14CC PLLCFG 14B8 PLLCON 14A4 PLL
1490 MEMMAP 147C MAMTIM 1468 MAMCR
1454 MAM 1440 IOCLR 142C IODIR
1418 IOSET 1404 IOPIN 13F0 IO
13E0 PINSEL1 13C8 PINSEL0 13B0 PINSEL
1394 VICVectCntl 1378 VICVectCntl0 1354 VICVectAddr
1338 VICVectAddr0 131C VICDefVectAddr 1300 VICVectAddr
12E4 VICProtection 12C8 VICSoftIntClr 12AC VICSoftInt
1294 VICIntEnClr 1278 VICIntEnable 125C VICIntSelect
1240 VICRawIntr 1228 VICFIQStatus 120C VICIRQStatus
11F0 VIC 11DC TIB 11C8 HANDLER
11B0 PAD 119C key 1188 emit
1174 'EVAL 1160 NTIB 114C HLD
1138 UNUM 1124 DPL 1110 sign
10FC DIGITS 10E8 BASE 10D4 TEMP
10C0 LINES 10AC ERRORS 1098 FLAGS
1084 >IN 104C @USER 1038 UP!
1024 AUTO 1010 VP 1000 NP
FF0 CP FE0 DP FD0 CURRENT
FB8 CONTEXT FA0 forth F8C LAST
F78 ATRS F64 TCB F50 SYSCONS
F38 WHITE F24 CYAN F10 MAGENTA
EF8 BLUE EE4 YELLOW ED0 GREEN
EBC RED EA8 BLACK E94 OFF
E80 ON E70 URAM E5C -1
E4C FF E3C BL E2C 0F
E1C 0E E0C 0D DFC 0C
DEC 0B DDC 0A DCC 9
DBC 8 DAC 7 D9C 6
D8C 5 D7C 4 D6C 3
D5C 2 D4C 1 D3C 0
ABC .REGS A8C TRACE A74 SLEEP
A5C TIMING A44 GO A30 STOP
A18 @TASK 990 !TASK 914 -MS
878 0EXIT 860 ?EXIT 84C EXIT
83C RESET ok
_
