Lpc2000
setting up startup.s and environement for single chip lpc2294
2005-04-28 by dr350sesuzuki
My name is Thomas Mcdougall.
This is my first design with the ARM and i am having difficulty
getting my code to run after the board comes out of reset.
The board is running in single chip mode and we are using the internal
flash for program storage.
We are using the LPC2294 and the Keil Tool set and debugger.
I can successfully run and debug the code while using the Keil Ulink
debugger, but I cannot figure out what I have to do to get it to run
after reset with the debugger disconnected.  I have the boot0 and
boot1 pins pulled high at reset to boot from internal flash.
I started the project using the supplied blinky example which I
thought would set everything appropiately.
Any pointers as to what to do to get the board to boot is welcome.
TLM
Re: [lpc2000] setting up startup.s and environement for single chip lpc2294
2005-04-28 by Robert Wood
boot1 pins pulled high at reset to boot from internal flash.   <<
When I was getting my LPC2294 up and running I had the same problem
(albeit with a different compiler) and it was because P0.14 was low on
reset.
Check P1.20 as well, I have it marked on my schematic to pull this high
too. That might be something to do with using the port 1 pins as trace
pins, I can't remember off the top of my head.
IIRC if exception vector checksum is incorrect it could affect boot.
Rob
RE: [lpc2000] setting up startup.s and environement for single chip lpc2294
2005-04-30 by Thomas McDougall
That was exactly what it was.  I had contact Keil and they said it
looked like my software was fine so I then check pin by pin my design to
the data sheet to check I had the pins all in the proper state at reset.
I found I had the bootloader pin tied low rather than high.  Tying it
high fixed the problem.
Thanks for the assistance.
TLM
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Robert Wood
Sent: Thursday, April 28, 2005 10:05 AM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] setting up startup.s and environement for single
chip lpc2294
reset.
Rob
  _____
Yahoo! Groups Links
*         To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*         To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*         Your use of Yahoo! Groups is subject to the Yahoo! Terms of
<http://docs.yahoo.com/info/terms/>  Service.
