LPC2106 port driving problem (longer post)
2005-05-03 by roger_lynx
Hello,
I need to write a nibble to P0.31-P0.28. When I write a value, it is
not output correctly:
ex. I write 0x7E 5C 38 A1 sequence and
I get out 0x7C 4C 38 80 sequence, sometimes the bit(s) get sticky on
P0.29/28, seldom on P0.31.
I use IOSET/IOCLR, I gave up on IOPIN, since the waveform is "too
analog". :-)(slow rise/fall time)
I found this explanation, in 2131_UM, pg. 88:
Write access to port�s IOSET followed by write to the IOCLR
register
results with pins outputting 0s being slightly later then pins
outputting 1s. There are systems that can tolerate this delay of a
valid output, but for some applications simultaneous output of
a binary content (mixed 0s and 1s) within a group of pins on a single
GPIO port is required. This can be accomplished by writing
to the port�s IOPIN register.
Following code will preserve existing output on PORT0 pins P0.[31:16]
and P0.[7:0] and at the same time set P0.[15:8] to 0xA5,
regardless of the previous value of pins P0.[15:8]:
IO0PIN = (IO0PIN && #0xFFFF00FF) || #0x0000A500
....etc.
My questions are:
1. Is this example correct? If so, *why* is it correct?
2. Is pin behaviour on 2106 same as another LPC member, such as 2131?
3. Is GPIO 31-28 really *General*?
4. I tested this code:
_pin_toggle:
ldr r0, =IODIR
mov r1, #0x80
mov r3, #0x80
str r1, [r0]
ldr r0, =IOCLR
ldr r2, =IOSET
L3:
str r1, [r0]
str r1, [r2]
b L3
I got 3.4+ MHz pin state change rate, I need now fraction of it, yet I
cannot get it.
VPBDIV=1.
Please, advise.
(am using GNU 3.3.1, I looked at assembled code, I see nothing
strange)
Thank you.
--roger
