--- In lpc2000@yahoogroups.com, "Gus" <gus_is_working@y...> wrote:
> Hello,
> I need to move data fast between 2 I2C devices ASAP. One device is a
> PIC18F458 micro and the other is an LPC2114 micro.
> 1) Is it best if I set up one as a slave and the other as master or
> it is better to set them up both as master/slave?
The fastest possible way, and the most straight-fwd, given your line
of questions...is to ALWAYS rig up ONE master, and everything else as
SLAVES.
> 2) It seems to be too slow to do stop/start conditions when sending
> data. If data is going both dirrections at the same time, is there a
> way to come over start/stop condisions?
Yes, If you have a single MASTER, multiple slave system, then the
master can always send a repeat start condition, this will maybe save
a few microseconds...not much, but it is a bit more efficient...
> 3) What address am I allowed to use on I2C? Is there legal issues on
> using sertain I2C addresses? I can only use 7-bit addressing
There are no legal issues with I2C addresses. You can pretty much use
any 7-bit address you want. You need to be wary though. If you use ANY
address, then you will then be unable to use the wide plethora of
currently available I2C silicon there is out there!
Another brief note about multi-master systems...
Multi-master systems are a pretty cool, yet fraught with pitfalls,
feature of I2C. In other words, very tricky, but very rewarding once
you have the system fully debugged.
There are only four modes you need to deal with for multi-master
systems. They are:
--> Master transmit
--> Master receive
--> Slave transmit
--> Slave receive
Non-intelligent I2C devices ALWAYS communicate slave transmit and
slave receive modes. In general, when I program up a multi-master
system, I usually create four (4) separarate buffers. One buffer for
each mode of operations. In this way, you will, (at the expense of
memory), will be able to create a pretty efficient multi-master I2C
device driver....
Do not worry about contention in a multi-master I2C using the LPC2xxx
device. The LPC2xxx silicon is modeled after the venerable Philips
80c5xx chip. This I2C silicon has every single I2C vector that is
defined in the I2C specification! Including generating interrupts on a
contention violation!
Hope this long-winded explanation helps.
Ken Wada
