--- In lpc2000@yahoogroups.com, "Anton Erasmus" <antone@s...> wrote:
> On 1 Jun 2005 at 13:43, alipowsky wrote:
> > I want to use P3.29 (Pin 27, P3.29/BLS2/AIN6) as GPIO (output)
> > The manual says it can be done by setting Bit 6 of PINSEL2 to zero.
> > my testcode:
> > PINSEL2 &= 0xffffffbf; // Reset PINSEL2.6 to config P3.29 as GPIO
> > IO3DIR |= 0x20000000; // Set P2.29 as output IO3SET = 0x20000000;
> > // Set portpin high
> > But the pin does not go high ??
> > Did anybody use this pin as GPIO output already ?
> Which header files are you using ? (i.e. where do you define
PINSEL2, IO3DIR etc.)
> I used the header files from aeolus development, and there was a
mistake with one of
> definitions doe IO Port 3. (Copy/Paste mistake - same value for port
2 and port 3)
> Regards
> Anton Erasmus
> A J Erasmus
I use the Rowley header files. (Crossworks for ARM v.1.4)
Thea are okay. I also checked the assembler code and the adresses
there are as expected:
PINSEL2: 0xe002c014
IO3DIR: 0xe0028038
IO3SET: 0xe0028034
regards
Andreas
