Lpc2000
Non-Volatile Memory
Non-Volatile Memory
2005-06-09 by Tom Convent
Hello Guys,
                   LPC devices had an non-volatile area where variables can be initialliazed to hold values even after power switch off or processor reset. I want to write a program where I can store a byte and read the same byte after processor power on (the variable byte would not loose data even processor is switch off).
Can someone puts light on how to achieve this task ?? does someone sloved this problem before ??
should I store my variable in non-volatile area ??
waiting for your replies guys.
Thanks, TOM
Do You Yahoo!?
http://mail.yahoo.com
Re_ [lpc2000] Non-Volatile Memory
2005-06-09 by Ralf Knorr
Hi Tom,
I'm using 2106 and 2114 and I think the only possible way to store
internal data is to use the IAP function. But than you will use minimum
an 8kB flash sector to store only one byte. Important is also, that you
can only erase the whole 8kB sector completely. for storing data in a nv
area I use an extern I2C eeprom.
Ralf
Tom Convent schrieb:
> Hello Guys,
> Thanks, TOM
> Do You Yahoo!?
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Mit freundlichen Gr\ufffd\ufffden / Best regards
Ralf Knorr
___________________________________________________________________________________________
* Author: *
Dipl.-Ing. Ralf Knorr (FH)
Development: Area leader Software
Bury GmbH & Co KG
Robert-Koch-Str. 1-7
32584 L\ufffdhne
Germany
*Phone:*     +49 (0) 5732 9706 0
*Fax:*          +49 (0) 5732 9706 209
*Email:*       knorr@... <mailto:knorr@...>
*Internet:*  http://www.thb.de <http://www.thb.de/>
This email and any files transmitted with it are confidential and
intended for the adressee only.
If you are not the adressee you may not copy, forward, disclose or
otherwise use it, or any part of it, in any form whatever.
If you have received this e-mail in error please notify the sender and
ensure that all copies of this e-mail and any files transmitted with it
are deleted.
Any views or opinions represented in this e-mail are solely those of the
author and do not necessarily represented those of Bury GmbH &Co KG or
its affiliate companies.
Re: Re_ [lpc2000] Non-Volatile Memory
2005-06-10 by Sridhar gadda
Hello Ralf,
                      I agree with you that external eeprom is an option, but we have a choice to use NV-area of LPC so that overall cost of broad can come down significantly. Yes, but care to be taken that it erase 8KB sector.
 Tom  IAP functions are to be used to stroed internally.
thanks,
Sridhar
Ralf Knorr <knorr@...> wrote:
Hi Tom,
Ralf
> Hello Guys,
> Thanks, TOM
> Do You Yahoo!?
Mit freundlichen Grüßen / Best regards
Ralf Knorr
* Author: *
Bury GmbH & Co KG
32584 Löhne
Germany
are deleted.
Yahoo! Groups Links
Do You Yahoo!?
RE: Re_ [lpc2000] Non-Volatile Memory
2005-06-10 by Matthias Hertel
Hello Sridhar,
you should consider the I2C EEPROM if you have a lot of write cycles to that
memory area. It is cheaper to replace in the circuit when it should fail. If
there are only sporadic memory writes you should use the on-chip flash,
because read access is a lot faster
Matthias
  _____
sentto-11453166-7604-1118393519-matthias.hertel=web.de@...ups.yahoo.
com
[mailto:sentto-11453166-7604-1118393519-matthias.hertel=web.de@...
s.yahoo.com] On Behalf Of Sridhar gadda
Sent: Friday, June 10, 2005 10:52 AM
To: lpc2000@yahoogroups.com
Subject: Re: Re_ [lpc2000] Non-Volatile Memory
Hello Ralf,
thanks,
Sridhar
Hi Tom,
Ralf
> Hello Guys,
> Thanks, TOM
> Do You Yahoo!?
Ralf Knorr
_______________
* Author: *
Bury GmbH & Co KG
32584 Löhne
Germany
are deleted.
_______________
Yahoo! Groups Links
Do You Yahoo!?
  _____
Yahoo! Groups Links
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
2005-06-10 by Tom Convent
Hello,
            I just want to experiment that I stored a variable of 8bits at non-volatile area, switch off processor and read the same variable in next power on.
 Does anyone of you written IAP function ?? I would be thankful if someone forward IAP code.  I am using lpc2129 and Keil enviornment.
once again thanks guys
Tom Convent
Matthias Hertel <matthias.hertel@...> wrote:
Hello Sridhar,
Matthias
  _____
sentto-11453166-7604-1118393519-matthias.hertel=web.de@....
com
Hello Ralf,
thanks,
Sridhar
Hi Tom,
Ralf
> Hello Guys,
> Thanks, TOM
> Do You Yahoo!?
Ralf Knorr
_______________
* Author: *
Bury GmbH & Co KG
32584 Löhne
Germany
*Email:*       knorr@thb.de <mailto:knorr@...>
are deleted.
_______________
Yahoo! Groups Links
Do You Yahoo!?
  _____
Yahoo! Groups Links
Yahoo! Groups Links
Discover Yahoo!
 Find restaurants, movies, travel & more fun for the weekend. Check it out!
http://www.keil.com/download/docs/298.asp
  _____
sentto-11453166-7607-1118406630-matthias.hertel=web.de@....
com
[mailto:sentto-11453166-7607-1118406630-matthias.hertel=web.de@...
s.yahoo.com] On Behalf Of Tom Convent
Sent: Friday, June 10, 2005 2:30 PM
Subject: RE: Re_ [lpc2000] Non-Volatile Memory
Hello,
power on.
Tom Convent
Hello Sridhar,
Matthias
  _____
com
Hello Ralf,
thanks,
Sridhar
Hi Tom,
Ralf
> Hello Guys,
> Thanks, TOM
> Do You Yahoo!?
>       lpc2000-unsubscribe@...m
Ralf Knorr
_______________
* Author: *
Bury GmbH & Co KG
32584 Löhne
Germany
are deleted.
_______________
Yahoo! Groups Links
Do You Yahoo!?
  _____
Yahoo! Groups Links
Yahoo! Groups Links
Discover Yahoo!
  _____
Yahoo! Groups Links
2005-06-10 by johnthomasedwardtimm
If you have a free 8 KB sector, why not write successive 32 byte
blocks until you reach the end of the sector and then erase.  You can
search linearly to find the most recent block of nv-data (blank flash
is all "f's").  This method works well and adheres to the
various "rules" regarding flash programming.
JT
