Disable RX on UARTS
2005-06-15 by extra300_it
Hello, I have an external circuit that echoes back the caracters that I am sending out of UARTs. Is there any way to disable RX while I'm transmitting (like Rx Enable on other micros)? -I am using FIFO- I disabled both RX interrupts during transmission. When tx is ended, I clear FIFO buffers (UxFCR bit 1) This should clear the RX FIFO buffer, isn't it? When I re-enable RX interrupts I get in RX several times the last char that was sent. Any suggestion? Thanks.
