seems this needs a little clarification what is FullCAN and what is
filtering. First of all FullCAN and filtering are not really related!
You can filter literally hundreds of messages with the CAN
implementation on the LPC2129 while the maximum number of messages
filtering options on FullCAN devices that I know allows 64 messages
to be filtered. This filtering is independent of the FullCAN (and
its Errata)
FullCAN means that received messages are handled by an internal state
machine that could be compared to a "one message DMA". The message ID
is used to filter but also to assign the final destination in the
buffer RAM. If you receive 10 different messages with a FullCAN
device, there is no need to read any of them before the next is
received. Only the second reception of a message with a previously
received identifier will overwrite that message.
Let's call the mode on the LPC21x9 a "GateWay Mode", in the GW mode,
all (filtered) messages are received in the same receive register and
the CPU has to take care of the data before the next message is
completely received. Given the performance of the LPC21x9 this is not
a problem at all.
Again, in the GW mode ONLY FILTERED MESSAGES are received but each
received messages has to be offloaded from the receive register
before the next message is completely received.
In worst case you have got approx. 30 usec time between a data frame
and a Remote Frame to handle a message. This is up to 1400
instruction times at 48 MHz (best for 1 Mbit CAN transfers).
Summary: Filtering in the GW mode is superior to any existing FullCAN
implementation but the CPU / your software has to take care of the
received messages.
The Errata for FullCAN has nothing to do with the filtering in the GW
mode.
Hope this helps, Robert
--- In lpc2000@yahoogroups.com, Hong Jiang <smartpite@y...> wrote:
> Hi,all members:
> I used the LPC2119 ARM CPU to act as a protocol transformation
from UART to CAN.Now I have realized this function,but I can only
recognize the CAN ID by comparing it with a ID stored in my flash.So
there are still many works about ACCEPTANCE FILTER to be done.
> The problem is how can I realize the FULL CAN feature.
> Thanks!
> DO YOU YAHOO!?
> ÑÅ»¢Ãâ·ÑGÓÊÏä£ÖйúµÚÒ»¾øÎÞÀ¬»øÓʼþɧÈų¬´óÓÊÏä
