Lpc2000
OT: Is there an easy way to convert expressPCB files to EAGLE files?
2005-06-24 by Pigeon
Hello, I have had a schematic done in expressPCB program.. and Now I want to show this file to someone else.. The issue is he only has eagle.
What is the easiest way t oconvert between the 2?
I have tried exporting from expresspcb to everything i can export to.. and that doesn't help:/
thanks
Lee Leathers
Re: [lpc2000] OT: Is there an easy way to convert expressPCB files to EAGLE files?
2005-06-24 by Richard Duits
You can always convert to pdf. He will not be able to edit the
schematic, but he can always view it. There are lots of free utils out
there to create or read pdf files.
RD
> thanks
> Lee Leathers
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-06-25 by Robert Adsett
Isn't expressPCB designed to prevent you from doing that?  I was under the
impression that one of their main design goals was to lock you into using
their services.  The ability to export to a 'real' CAD program would run
counter to that. I didn't think they even produced standard Gerber files
much less allowed export into any format that could be read intelligently
by any other program.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
