Lpc2000
Reading from flash
Reading from flash
2005-06-28 by albin_martinsson
Hi
Anyone knows why I get some bit-errors when I am reading from the
flashmemory. In my program I store some data (texts and other
configurations) with the IAP routines. But if I compare the recently
written data from RAM with the programmed data from Flash there are
some bits that has changed, resulting in a checksum error for the
data I have written to Flash. But!  when i do a memory dump from the
flash memory with the LPC2100-program I always read the correct data.
I read from Flash by pointing a byte pointer like this:
tU8 *ptr;
flashaddress = 0x00020000;
ptr = (tU8 *)flashaddress;
When i turned off the MAM funktion the error reduced but there are
still some errors.
Can someone explain why this is so?
B.R  /Fredrik Martinsson
RE: [lpc2000] Reading from flash
2005-06-28 by Dan Beadle
The JTAG dump does not run at the same speed as the internal FLASH.
(Generally slower).  I would GUESS that you might have the MAM set up
too fast or the PLL too fast.  This could cause FLASH to read back
incorrectly at execution time, but the slower JTAG dump would read it
correctly.
Dan
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of albin_martinsson
Sent: Monday, June 27, 2005 11:29 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Reading from flash
Hi
tU8 *ptr;
still some errors.
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
Re: Reading from flash
Hi
Thanks for the quick answer,
the MAM is disabled,
PLL is set to MUL with 4  (clock freq * (4+1))
Im using the MCB2100 so the clock freq is 12 MHz and with the PLL
the running speed is 60MHz.
Do you think its better to slower down the PLL or should I configure
the MAM function?
/FM
up
it
> correctly.
> Dan
>   _____
Behalf
> Of albin_martinsson
> Hi
recently
are
data.
> tU8 *ptr;
> still some errors.
>   _____
> YAHOO! GROUPS LINKS
>   _____
RE: [lpc2000] Re: Reading from flash
It sure sounds like you have it configured correctly.  I would try going
with the default speeds and see if you have any issues (12MHz).  If the
symptom goes away, you know you are on the right track.
Dan
  _____
Of albin_martinsson
Sent: Monday, June 27, 2005 11:50 PM
Subject: [lpc2000] Re: Reading from flash
Hi
the MAM function?
/FM
up
it
> correctly.
> Dan
>   _____
Behalf
> Of albin_martinsson
> Hi
recently
are
data.
> tU8 *ptr;
> still some errors.
>   _____
> YAHOO! GROUPS LINKS
>   _____
  _____
YAHOO! GROUPS LINKS
  _____
Ok,
I have now set the system clock to 24 MHz and it works fine. Thanks
for all help, now I am going to trim up the speed to see were the
limit is. But i still think it is strange that it can't run at
60MHz, it should according to the DS. In the real application were
running with a 20Mhz osc so I think the limit there would be 40 MHz.
Thanks for all help Dan.
/FM
going
If the
> Dan
>   _____
Behalf
> Of albin_martinsson
> Hi
configure
> the MAM function?
> /FM
FLASH.
set
> up
back
read
> it
> > correctly.
> > Dan
> >   _____
On
> Behalf
> > Of albin_martinsson
> > Hi
> recently
> are
> the
> data.
> > tU8 *ptr;
are
> > still some errors.
> >   _____
> > YAHOO! GROUPS LINKS
of
> >   _____
>   _____
> YAHOO! GROUPS LINKS
>   _____
SSP_SPI1 Read
2005-06-28 by sudip nag
Hi Everyone,
I am using LPC2138's SSP Controller (SPI1) in SPI mode. I am successful in sending data to SPI slave device. But confused how to read data from slave. If not mistaken, during read operation SPI master will provide the SCK signal to the slave. How to do this task with SSP.
Thanks.
Sudip Nag
How much free photo storage do you get? Store your friends n family photos for FREE with Yahoo! Photos.
 http://in.photos.yahoo.com
Re: [lpc2000] SSP_SPI1 Read
2005-06-28 by Don Williams
Im about to implement this design in copper and assume (hope?) I know whats
happening - but I dont understand ur question. With LPC2138 as master in
receive mode the data sheet is clear about SCK1 being asserted afetr SSEL1
goes low - where it will stay for the duration of the 8 or 16 bit transfer.
After 8 or 16th clk edge sck1 is disabled and SSEL1 goes hi again so the
transaction is over.
Whats the problem ?
Don Williams
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, June 28, 2005 8:13 PM
Subject: [lpc2000] SSP_SPI1 Read
> Hi Everyone,
> Thanks.
> Sudip Nag
2005-06-29 by sudip nag
Hi Don,
I am using 8-bit mode with DS1306 RTC. The 8bit address+command is to be supplied from master and 8bit data from slave will go to the master (DS1306 read). After I send 8bit from MCU, SCK stops. Thus MISO do not receive anything. Thus I never read any data in MCU.
Sudip
Whats the problem ?
Don Williams
> Hi Everyone,
> Thanks.
> Sudip Nag
YAHOO! GROUPS LINKS
 Too much spam in your inbox? Yahoo! Mail gives you the best spam protection for FREE!
http://in.mail.yahoo.com
