Lpc2000
difficulties at using IAP routines
2005-07-01 by cris_ullmann
Hello friends,
I'm still pretty unexperienced in programming the LPC2xxx processors.
I want read and write the internal flash using IAP. At first, I tried
to read the processor ID from the flash.
My code is:
int IAP_ID()
#define IAP_LOCATION 0x7FFFFFF1
unsigned int command[5];
unsigned int result[2];
typedef void (*IAP)(unsigned int[],unsigned int[]);
IAP iap_entry;
int ID;
int Ergebnis;
  __DISABLE_INTERRUPT();
 iap_entry=(IAP)IAP_LOCATION;
 command[0]=54;             //read par ID
 result[0]=0;
 iap_entry(command,result);
 Ergebnis=result[0];
 ID=result[1];
 return Ergebnis;
By the way, I use the CCARM compiler, the boot loader version is 1.64
Is there anybody who can help me? As I learned from this forum, the
problem might laying in switching to the thumb mode when calling the
IAP-routine. Who do I have to do this?
Best regards
Cris
Hello friends,
My code is:
int IAP_ID()
IAP iap_entry;
int ID;
int Ergebnis;
 result[0]=0;
 Ergebnis=result[0];
 ID=result[1];
 return Ergebnis;
By the way, I use the ICCARM compiler, the boot loader version is 1.64
Best regards
Cris
Re: [lpc2000] difficulties at using IAP routines
2005-07-03 by Tom Convent
Hello Cris,
                 In your code result[1] contains the ID...you should return result[1] instead of result[0]. results[0] only says the cammand is sucess.
regards,
Tom
cris_ullmann <cris.ullmann@...> wrote:
Hello friends,
My code is:
int IAP_ID()
IAP iap_entry;
int ID;
int Ergebnis;
result[0]=0;
Ergebnis=result[0];
ID=result[1];
return Ergebnis;
Best regards
Cris
YAHOO! GROUPS LINKS
Do You Yahoo!?
http://mail.yahoo.com
Re: difficulties at using IAP routines
2005-07-03 by cris_ullmann
Hi Tom,
thank you for your help. The result is still not my problem. I changed
that sometimes from reslut[1] to result[0].
The problem is, the programm sticks at the call of the IAS-routine.
Any idea??
Best regards  Cris
--- In lpc2000@yahoogroups.com, Tom Convent <ur_tom1977@y...> wrote:
> Hello Cris,
cammand is sucess.
> regards,
> Tom
> cris_ullmann <cris.ullmann@t...> wrote:
> Hello friends,
> My code is:
> int IAP_ID()
> IAP iap_entry;
> int ID;
> int Ergebnis;
> result[0]=0;
> Ergebnis=result[0];
> ID=result[1];
> return Ergebnis;
> Best regards
> Cris
> YAHOO! GROUPS LINKS
Service.
> Do You Yahoo!?
2005-07-05 by Dave
--- In lpc2000@yahoogroups.com, "cris_ullmann" <cris.ullmann@t...> wrote:
> Hi Tom,
> Any idea??
> Best regards  Cris
> > Hello Cris,
> cammand is sucess.
> > regards,
> > Tom
> > Hello friends,
> > My code is:
> > int IAP_ID()
> > IAP iap_entry;
> > int ID;
> > int Ergebnis;
> > result[0]=0;
> > Ergebnis=result[0];
> > ID=result[1];
> > return Ergebnis;
> > Best regards
> > Cris
> > YAHOO! GROUPS LINKS
> Service.
> > Do You Yahoo!?
Hello,
  I have had success using the IAP commands to extract partID and
bootloader version. I have also managed to program the flash once.
However, I cannot erase the flash sector that I managed to program, so
that I may program it again. Also, the flash programming call seems to
'stick', but if left long enough eventually comes back. The functions
to read partID and bootloader version do not require interrupts to be
disabled, or the PLL to be disabled, or the MAM to be disabled. The
flash programming functions require all of these to be disabled.
// IAP (In Application Programming) interface
struct iap_in {
  unsigned int cmd;
  unsigned int par[4];
typedef void (*IAP)(struct iap_in *in, unsigned int *result);
// IAP entry point
#define iap_entry ((IAP) 0x7FFFFFF1)
// IAP command codes
#define IAP_PREPARE_WRITE				50
#define IAP_PROGRAM_FLASH				51
#define IAP_ERASE_SECTOR				52
#define IAP_BLANK_CHECK					53
#define IAP_READ_PART_ID				54
#define IAP_READ_BOOT_CODE_VER			55
#define IAP_COMPARE						56
#define IAP_REINVOKE_ISP				57
// IAP return code values
#define IAP_RESULT_SUCCESS				0
#define IAP_RESULT_INVALID_COMMAND		1
#define IAP_RESULT_SRC_ADDR_ERROR		2
#define IAP_RESULT_DST_ADDR_ERROR		3
#define IAP_RESULT_SRC_ADDR_NOT_MAPPED	4
#define IAP_RESULT_DST_ADDR_NOT_MAPPED	5
#define IAP_RESULT_COUNT_ERROR			6
#define IAP_RESULT_INVALID_SECTOR		7
#define IAP_RESULT_SECTOR_NOT_BLANK		8
#define IAP_RESULT_SECTOR_NOT_PREPARED	9
#define IAP_RESULT_COMPARE_ERROR		10
#define IAP_RESULT_BUSY					11
// IAP Read Part Identification command
// This command is used to read the part identification number.
//  device   code(dec)  code(hex)
//	LPC2131     196353  0x0002 FF01
//  LPC2132     196369  0x0002 FF11
//  LPC2134     196370  0x0002 FF12
//  LPC2136     196387  0x0002 FF23
//  LPC2138     196389  0x0002 FF25
static unsigned int iap_read_part_id(void)
	// IAP input parameters
	struct iap_in iap;
	// IAP results
	iap.cmd = IAP_READ_PART_ID;
	iap_entry (&iap, result);
	return result[1];
// IAP Read Boot code version number command
// This command is used to read the boot code version number.
static unsigned int iap_read_boot_code_version(void)
	struct iap_in iap;
	// IAP results
	iap.cmd = IAP_READ_BOOT_CODE_VER;
	// 2 bytes of boot code version number in ASCII format.
	// It is to be interpreted as <byte1(Major)>.<byte0(Minor)>
	return result[1];
typedef struct partIDToDesc_s {
	unsigned int id;
	char* desc;
partIDToDesc_t;
#define NUM_PART_IDS	5
static partIDToDesc_t partIDs[NUM_PART_IDS] = {
	//  device   code(dec)
	{196353, "LPC2131"},	//	LPC2131     196353  0x0002 FF01
	{196369, "LPC2132"},	//  LPC2132     196369  0x0002 FF11
	{196370, "LPC2134"},	//  LPC2134     196370  0x0002 FF12
	{196387, "LPC2136"},	//  LPC2136     196387  0x0002 FF23
	{196389, "LPC2138"},	//  LPC2138     196389  0x0002 FF25
unsigned int flashGetPartID(void)
	return part_id;
char* flashGetPartName(unsigned int part_id)
	char* name = "Unknown";
	for (int i = 0; i < NUM_PART_IDS; i++) {
		if (part_id == partIDs[i].id) {
			name = partIDs[i].desc;
			break;
	return name;
unsigned int flashGetBootloaderVersion(void)
	return iap_read_boot_code_version();
2005-07-05 by valdef78
wrote:
> Hi Tom,
changed
> Any idea??
> Best regards  Cris
I'm still a "newbie" at LPC & ARM7, but I already read many things
about it, so maybe I can suggest one thing.. the IAP functions (&
ISP) use RAM for stack and for data storage, so your boot and linker
file should be careful that your own code and stacks didn't overlap
it..
"RAM used by IAP command handler :
Flash programming commands use the top 32 bytes of on-chip RAM. The
maximum stack usage in the user allocated stack space is 128 bytes
and it grows downwards."
Re: [lpc2000] Re: difficulties at using IAP routines
2005-07-05 by Tom Convent
Hello dave,
                  Writing to flash and errasing dont need to disable PLL, MAM or interrupts. It worked fine for me.
bye
Tom
> Hi Tom,
> Any idea??
> Best regards  Cris
> > Hello Cris,
> cammand is sucess.
> > regards,
> > Tom
> > Hello friends,
> > My code is:
> > int IAP_ID()
> > IAP iap_entry;
> > int ID;
> > int Ergebnis;
> > result[0]=0;
> > Ergebnis=result[0];
> > ID=result[1];
> > return Ergebnis;
> > Best regards
> > Cris
> > YAHOO! GROUPS LINKS
> Service.
> > Do You Yahoo!?
Hello,
struct iap_in {
  unsigned int cmd;
// IAP entry point
      struct iap_in iap;
      // IAP results
      return result[1];
      struct iap_in iap;
      // IAP results
      return result[1];
      unsigned int id;
      char* desc;
partIDToDesc_t;
      //  device   code(dec)
      return part_id;
                  break;
      return name;
YAHOO! GROUPS LINKS
Yahoo! Sports
 Rekindle the Rivalries. Sign up for Fantasy Football
2005-07-06 by Dave
> wrote:
> > Hi Tom,
> changed
> > Any idea??
> > Best regards  Cris
> it..
Hello,
  Yes indeed, after adjusting the startup code to reserve those top
32bytes everything works. yay.
  However, the 64k flash chip I have, segments the flash so that the
top 32k is one segment. But I only want a 4k segment for configuration
storage. Now, startup and asm irq wrappers go in the first 4k segment,
the next 4k is reserved for the configuraion and then the rest of the
code goes from the third segment onto the end.
Dave
