Lpc2000
Re: [lpc2000] GNU inline assembler return value
2005-07-11 by 42Bastian Schick
xjag74 <detlef.weidner@...> schrieb am Mon, 11 Jul 2005 15:00:32
-0000:
> Hi,
> I wonder why GCC don't compile that simple code:
> static inline unsigned StackPointerValue(void)
>  unsigned long val;
>  asm volatile (" str R13, retval");
>  return val;
> When I try to compile the following error appears:
> "Internal_relocation (type: OFFSET_IMM) not fixed up"
gcc (or better gas) does not know anything about retval, so it takes it
as external and gets confused.
This works:
long sp(void)
   long val;
   asm(" mov %r0,sp":"=r"(val));
   return val;
> What does that mean? How can I get that running?
> Best regards
> XJAG74
42Bastian Schick
2005-07-11 by Bill Knight
On Mon, 11 Jul 2005 15:00:32 -0000, xjag74 wrote:
>Hi,
> unsigned long val;
> return val;
1st, 'retval' is not 'val'
I haven't compiled this but try
 unsigned long retval;
 asm volatile (" str sp, %0" : "=r" (retval) : /* no inputs */ );
 return retval;
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
2005-07-11 by Richard Duits
Copying one register to another is done with the "mov" instruction:
asm volatile ("mov sp, %0" : "=r" (retval) : /* no inputs */ );
return retval;
An alternative in this case would be:
unsigned long stackptr __asm("sp");
return stackptr;
Richard Duits
> >Hi,
> > unsigned long val;
> > return val;
> return retval;
> Regards
> -Bill Knight
> R O SoftWare &
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
I made a few errors in this short post...
Destination register should be on the left:
asm volatile ("mov %0, sp" : "=r" (retval) : /* no inputs */ );
return retval;
and the __asm keyword only works if you include the register keyword and
this will generate a warning about using an uninitialized variable:
register unsigned long stackptr __asm("sp");
return stackptr;
Richard Duits
> return retval;
> return stackptr;
> Regards,
> Richard Duits
> > >Hi,
> > > unsigned long val;
> > > return val;
> > return retval;
> > Regards
> > -Bill Knight
> > R O SoftWare &
> > YAHOO! GROUPS LINKS
> YAHOO! GROUPS LINKS
yes, I blew it.  Didn't check the docs and had my head on a totally
different project.  Saw the correct answer shortly after posting mine.
-Bill
>return retval;
>return stackptr;
>Regards,
>Richard Duits
>> >Hi,
>> > unsigned long val;
>> > return val;
>> return retval;
>> Regards
>> -Bill Knight
>> R O SoftWare &
>> YAHOO! GROUPS LINKS
>Yahoo! Groups Links
Re: GNU inline assembler return value
2005-07-12 by xjag74
Thank you, that's it!
For GCC you have to type:
    register unsigned long stackptr asm("sp");
    return stackptr;
xjag
mine.
> -Bill
> >return retval;
> >return stackptr;
> >Regards,
> >Richard Duits
> >> >Hi,
> >> > unsigned long val;
> >> > return val;
yes, I know it was late ;-)
> >> return retval;
> >> Regards
> >> -Bill Knight
> >> R O SoftWare &
> >> YAHOO! GROUPS LINKS
of
> >Yahoo! Groups Links
Now I realized that the interrupts use another stack (IRQ stack) than
a normal routine (User stack).
Is it possible to read the User stack pointer within the ISR?
What I try to do is to capture the SP every timer1 ISR entry (200us)
and to store the maximum value to figure out if the stack collides
with the data area.
The stack check option of the GNU compiler is not working.
xjag
>     return stackptr;
> Regards
> xjag
totally
> mine.
> > -Bill
instruction:
> > >return retval;
> > >return stackptr;
> > >Regards,
> > >Richard Duits
> > >> >Hi,
> > >> > unsigned long val;
> > >> > return val;
> > >> return retval;
> > >> Regards
> > >> -Bill Knight
> > >> R O SoftWare &
> > >> YAHOO! GROUPS LINKS
Terms
> of
> > >Yahoo! Groups Links
2005-07-12 by brendanmurphy37
Xjag,
If you're looking for possible stack overrun, have you tried
initialising the stack area to a particular value (e.g. 0xdead)? By
looking at memory you can determine easily if it has been
overrunning. This is a useful technique for determining how much
stack space is actually required on a given system: you can
overdimension at the start, look at how much is actually used and re-
dimension accordingly (leaving some safety margin in).
Our standard start-up code writes different values to each of the
three stacks (supervisor, IRQ and FIQ stacks), as an aid to
debugging. I'll dig this code out if it helps.
Brendan
than
(200us)
> with the data area.
> Regards
> xjag
> >     return stackptr;
> > Regards
> > xjag
> totally
posting
> > mine.
> > > -Bill
> instruction:
> > > >return retval;
> > > >return stackptr;
> > > >Regards,
> > > >Richard Duits
> > > >> >Hi,
> > > >> > unsigned long val;
> > > >> > return val;
> > > >> return retval;
> > > >> Regards
> > > >> -Bill Knight
> > > >> R O SoftWare &
> > > >> YAHOO! GROUPS LINKS
> Terms
> > of
> > > >Yahoo! Groups Links
Re: [lpc2000] Re: GNU inline assembler return value
2005-07-12 by Charles Manning
> with the data area.
> Regards
> xjag
I think a better way to do this is to fill the stack area with a pattern and
see how much of the area is changed once the program has run for a bit.
2005-07-13 by xjag74
All right, thank you Charles and Brendan (parallel replies),
if that's the usual way then I'll code test pattern writing before
RAM copying in the startup.s file.
xjag
than
(200us)
> with the data area.
> Regards
> xjag
> >     return stackptr;
> > Regards
> > xjag
> totally
posting
> > mine.
> > > -Bill
> instruction:
> > > >return retval;
> > > >return stackptr;
> > > >Regards,
> > > >Richard Duits
> > > >> >Hi,
> > > >> > unsigned long val;
> > > >> > return val;
> > > >> return retval;
> > > >> Regards
> > > >> -Bill Knight
> > > >> R O SoftWare &
> > > >> YAHOO! GROUPS LINKS
> Terms
> > of
> > > >Yahoo! Groups Links
2005-07-13 by brendanmurphy37
Below is a simple startup sequence that fills the stack areas and
initialises overall state, before jumping to 'C'.
Please don't bother pointing out there are more efficient ways of
doing this: I know there are. It gets the job done....
Note that this is designed to work with a GNU link file which
reserves the space for the stacks as follows:
/* next section is .bss, which is uninitialised data */
.bss :
 __start_bss = . ;
/* include all uninitialised writable data */
 *(.bss)
/* include ramaining uninitialised data */
 *(COMMON)
 __end_bss = . ;
/* required allignment for stacks */
. =  ALIGN(0x10) ;
/* allocate room for supervisor stack */
 __tos_svc = . ;
 . += 0x800 ;
 __stack_svc = . ;
 /* allocate room for interrupt stack */
 __tos_irq = . ;
 . += 0x200 ;
 __stack_irq = . ;
/* allocate room for fast interrupt stack */
 __tos_fiq = . ;
  . += 0x100 ;
 __stack_fiq = . ;
} > ram
Hope this of some use to people.
Brendan
/* define values to use to zap stacks */
SVC_STACK_VALUE	= 0xaaaaaaaa
IRQ_STACK_VALUE	= 0xbbbbbbbb
FIQ_STACK_VALUE	= 0xcccccccc
 * Exception vector table, common to all ARM-based systems
 * See ARM Architecture Reference Manual, Programmer's Model section
for
 * details. Table entries just jump to handlers (using full 32-bit
addressing)
_int_vectors:
ldr		pc, do_reset_addr
nop
/* table of interrupt handler adresses */
do_reset_addr:	.long	do_reset
 * System reset handler
do_reset:
 * Set stack pointers for all modes used (supervisor, IRQ and FIQ)
msr	cpsr_c, #0xd3	 /* ensure we're in supervisor mode */
ldr	sp, =__stack_svc /* set supervisor mode stack pointer */
msr	cpsr_c, #0xd2	 /* enter IRQ mode, with interrupts disabled
ldr	sp, =__stack_irq /* set IRQ mode stack pointer */
msr	cpsr_c, #0xd1	 /* enter FIQ mode, with interrupts disabled
ldr	sp, =__stack_fiq /* set FIQ mode stack pointer */
/* now zap all stacks with distinctive pattern, to help detect
overflow */
ldr	r0, =__tos_svc
ldr	r1, =__stack_svc
ldr	r2, =SVC_STACK_VALUE
bl	zap_mem
ldr	r0, =__tos_irq
ldr	r1, =__stack_irq
ldr	r2, =IRQ_STACK_VALUE
bl	zap_mem
ldr	r0, =__tos_fiq
ldr	r1, =__stack_fiq
ldr	r2, =FIQ_STACK_VALUE
bl	zap_mem
 * Enable interrupts, enter supervisor mode and branch to start
 * of 'C' code
msr	cpsr_c, #0xc3		/* I=1 F=1 T=0 MODE=supervisor */
b	main
 * Function to zap a block of memory with specified value
 * Note that block MUST be word alligned
 * r0: start of block
 * r1: end of block
 * r2: value to load
 * lr: return address
zap_mem:
	cmp		r0, r1
	strlo	r2, [r0], #4
	blo		zap_mem
	mov		pc, lr
> Regards
> xjag
> than
> (200us)
collides
> > with the data area.
> > Regards
> > xjag
2005-07-14 by brendanmurphy37
OK - before anyone points it out, the comment in the code below just
before the call to "main" is wrong: interrupts are disabled (as you'd
expect, before anything has been setup) before jumping to "main".
Just goes to prove the point about never trusting comments, only the
code....
By the way, memory and other hardware initialisation is all done
in 'C' in this case: the less assembler the better, I think.
Brendan
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendan.murphy@i...> wrote:
> Hi,
> .bss :
>  __start_bss = . ;
>  *(.bss)
>  *(COMMON)
>  __end_bss = . ;
> . =  ALIGN(0x10) ;
>  __tos_svc = . ;
>  . += 0x800 ;
>  __stack_svc = . ;
>  __tos_irq = . ;
>  . += 0x200 ;
>  __stack_irq = . ;
>  __tos_fiq = . ;
>   . += 0x100 ;
>  __stack_fiq = . ;
> } > ram
> Regards
> Brendan
section
> for
> addressing)
> _int_vectors:
> nop
> do_reset:
> overflow */
> ldr	r0, =__tos_svc
> bl	zap_mem
> ldr	r0, =__tos_irq
> bl	zap_mem
> ldr	r0, =__tos_fiq
> bl	zap_mem
>  * of 'C' code
> b	main
>  * r1: end of block
>  * r2: value to load
> zap_mem:
> 	cmp		r0, r1
> 	strlo	r2, [r0], #4
> 	blo		zap_mem
> 	mov		pc, lr
before
> > Regards
> > xjag
stack)
> > than
> > (200us)
> collides
> > > with the data area.
> > > Regards
> > > xjag
2005-07-15 by 42Bastian Schick
brendan
But be really careful to use C before the C startup. This might work
on this chip with this compiler but fail on another.
(Seen e.g. on a V850 where some registers hold constant like 0xff and
0xffff
for masking.)
BTW: My opion adds one point:
If assembler then in a separate file, not inline.
42Bastian Schick
2005-07-15 by brendanmurphy37
Thanks for the comment, though I'm not sure what you mean by "C
startup"
Just to clarify:
- we use GCC as compiler for LPC2000
- we don't use any standard libraries: this avoids the most common
argument against GCC of large size overhead
- the startup is the assembler I included in previous e-mail
- the first thing the "main" does (in 'C') is to copy initialised
data
from flash to RAM, and clear out uninitialised data: after that it's
fully initialised
- all hardware setup is done from 'C', using MACROs to typecast the
register addresses to volatile integer pointers
- only other assembler used is a dispatcher for IRQ interrupts
(allowing nested interrupts), and the usual very small functions to
enable/disable interrupts etc.
I couldn't agree more with inline assebler: much better in a separate
assembler file.
Also, we don't use any special keywords for interrupt handlers:
they're
just declared as regular 'C' functions: the assembler dispatcher code
takes are of any special issues, such as additional register saves
etc.)
All this is geared to making the 'C' code as clean and "portable" as
possible, reducing dependencies on special compiler/dev tool features
as much as possible.
I'm not sure on you comment on the V850 as well: we use this
archiecture a lot. By the way, I'd highly recommend GCC for
generating
code that actually matches the source: we use IAR for V850 and have
had
a couple of very bad experiences of the compiler generating incorrect
code at high optimisation levels.
No doubt you've guessed I'm a bit wary of tools that come with large
amounts of built-in or generated code to "make things easier". Great
for playing around with a new system with, but if problems arise
(which
they will in any significant development), they're more a hinderence
than anything.
I guess I'm getting a bit "off-topic" here: though hopefully the
above
will be food for thought for some, though.
Thoughts anyone, on any of the above?
Brendan.
--- In lpc2000@yahoogroups.com, 42Bastian Schick <bastian42@m...>
wrote:
> brendan
and
> 0xffff
> for masking.)
> 42Bastian Schick
