Regarding the PWMEMR Register:
This is not a "secret register". In a preliminary version of the
User's Manual, this register was mentioned (as the PWM block is
closely related to the Timer blocks). This might be the reason why
Keil has mentioned this register in their header file. However, the
user doesn't need to do anything with this register in his PWM code.
This register can be simply disregarded.
We actually just noticed that the official LPC213x User's Manual is
now (finally) on the Philips Web site (not sure if this was
mentioned already):
http://www.semiconductors.philips.com/acrobat_download/usermanuals/UM
10120_1.pdf
We scanned it and as expected there is no reference to the PWMEMR
register anywhere.
LPC Tools
http://www.lpctools.com
--- In lpc2000@yahoogroups.com, "Klaus" <klaus276@y...> wrote:
> Hello Thomas,
> i contacted the keil support because of this example and that
special
> register. They confirmed, that the comments in this example are
wrong
> and they told me, that this register is "confidential". They
couldn't
> give me a description of it, but they promised me, that Keil would
> provide an example without this register " in the next days". That
was
> in December 2004.
> Klaus
> --- In lpc2000@yahoogroups.com, "Thomas Varghese" <tomv@t...>
wrote:
> > Hello,
> > My apologies if this has been beaten to death but I couldn't
find a
> > satisfactory answer.
> > I'm trying to implement a PWM output on an LPC2138, I see that
> > Keil example uses an PWMEMR register, but I couldn't find the
register
> > in the Philips documentation, nor in the include files under
IAR. The
> > "Insiders Guide to ARM7-Based Microcontrollers" also has the same
> > example and specifically says this register has to be set
otherwise
> > things will not work correctly.
> > I did find an address of 0xE001403C in the Keil include files.
Does
> > this have a different name under IAR or the regular Philips docs?
> > Any help/pointers would be appreciated.
> > Thanks.
> > Tom V.
