Lpc2000
Moving from 2106 to 2138
2005-07-26 by Nice Guy
In a school project we were originally going to use a 2106, but have
decided to move to a 2138 due to extra GPIO pins and External
Interrupts that are edge sensitve.  We have been sucessfully
developing for the 2106 with no problems using GCC and .ld and crt.s
files from an example project.  What will need to be changed when
going to the 2138.  I know the following will need to be corrected in
the .ld file:
/* Memory Definitions */
MEMORY
  ROM (rx) : ORIGIN = 0x00000000, LENGTH = 0x00020000
  RAM (rw) : ORIGIN = 0x40000000, LENGTH = 0x00010000
Is this all that will need to be changed?
Reggie McMurtrey
Re: Moving from 2106 to 2138
2005-07-26 by Thiadmer Riemersma (ITB CompuPhase)
That's basically it; you may also want to set the stack end in the .ld
file. Here are the top few lines from my lpc2138.ld file:
MEMORY {
   flash : ORIGIN = 0, LENGTH = 500K
   ram : ORIGIN = 0x40000000, LENGTH = 32K
__stack_end__ = 0x40000000 + 32K - 4;
One thing to look out for, is that the bootloader of the LPC2138 is 12
kiB, instead of 8 kiB of the LPC2106. That is why I set the Flash
length at 500 kiB (500 + 12 for the bootloader = 512 kiB).
Thiadmer
