Timer issues
2005-07-26 by soren_t_hansen
I'm having some problems with the timer on a lpc2132 in the following
way: I'm developing a program which I'm running from RAM while
debugging. I've set up MEMMAP=2 to remap the interrupt vectors and it
does work .... sometimes. Here goes ..
I use Eclipse with the Zylin embedded plugin. When I want to debug I
download the program and starts execution. But the first time I end up
in the DApt_Handler no matter what. Then I download the program once
more (without powercycling the board) and this time it all runs
without problems (I'm watching a global counter). If I then try to
download once more, it sometimes work and sometimes don't.
I have the ADC running at the same time and it suffers the same
problems, but if I run without the timer and just the ADC it works
like a charm. If I run the Timer without the ADC I still get the problem.
I have the following code to setup my timer:
// 15000 counts * 1/15 MHz = 1000 uS (1 kHz)
T0MR0 = 14999;
// Interrupt and Reset on MR0
T0MCR = 3;
// Timer0 Enable
T0TCR = 1;
// set interrupt vector
VICVectAddr1 = (unsigned long)tc0;
// use it for Timer 0 Interrupt
VICVectCntl1 = 0x20 | 4;
// Enable Timer0 Interrupt
VICIntEnable |= 0x00000010;
The interrupt handler looks like this:
void tc0 (void) __attribute__ ((interrupt ("IRQ")));
void tc0 (void)
count++;
// Clear interrupt flag
T0IR = 1;
// Acknowledge interrupt
VICVectAddr = 0;
Has anyone encountered this problem, or is able to see whats causing
the problem? I'm drawing blanks ...
Best Regards
Søren
