I2C does not generate interrupt after writing or reading
2005-08-01 by catstransport
I have a problem with my lpc2292.
The I2C bus does not generate a interrupt after a writing or a
reading. When I set the interrupt manually by setting the i2c
interrupt bit high then it comes in my isr routine.
I have tried several things but it all doesn't generate a interrupt.
best regards,
Remco
If one cannot enjoy reading a book over and over again, there is no use
in reading it at all.
-- Oscar Wilde2005-08-01 by James Dabbs
> I have a problem with my lpc2292. > The I2C bus does not generate a interrupt after a writing or > a reading. When I set the interrupt manually by setting the > i2c interrupt bit high then it comes in my isr routine. I am in the late stages of trudging through an interrupt-driven I2C interface for the 2106.. I believe it's the same hardware. The I2C system interrupts you only on a 'state change'. Therefore, you have to read/write the data port at the right time to result in an interrupt. In my case, I had to set the STA flag, write bytes, then set the STO flag. I got an interrupt after setting the STA flag and after each write. I can see how setting the interrupt bit high will force the issue but then your status register will probably only give you an 0xf8. Good luck.
--- In lpc2000@yahoogroups.com, "James Dabbs" <jdabbs@t...> wrote: > > I have a problem with my lpc2292. > > The I2C bus does not generate a interrupt after a writing or > > a reading. When I set the interrupt manually by setting the > > i2c interrupt bit high then it comes in my isr routine. > > I am in the late stages of trudging through an interrupt-driven I2C > interface for the 2106.. I believe it's the same hardware. > > The I2C system interrupts you only on a 'state change'. Therefore, you > have to read/write the data port at the right time to result in an > interrupt. In my case, I had to set the STA flag, write bytes, then set > the STO flag. I got an interrupt after setting the STA flag and after > each write. > > I can see how setting the interrupt bit high will force the issue but > then your status register will probably only give you an 0xf8. > > Good luck. I set my sta flag. And still I get no interrupt from the i2c. I is very strange. I will try writing it directly. Maybe that it helps.
> each write.
> Good luck.
I still have no luck with the I2C on the lpc2292.
My init for i2c are:
i2cconclr=0x6c; //i2conclr all bits
temp32 = pclk / 50000
scll = temp32/2
sclh = temp32-scll
i2conset = 0x40
The interrupt is set just like the uarts and those are working.
by writing to the i2c device i do this
clear stopbit
clear interrupt bit
i2conset 0x60 //set start flag
//set enable
then a wait till the isr change the status of my register.
but the isr does not start at all. i2c does not generate a interrupt.
Does anyone know what i do wrong.
regards,
Remco
