PWM settings
2005-08-01 by MattKav
I am confused about setting up the PWM code. Below is my initialization code. Here is my confustion... When I set PWMMR4 to 0, I get a very short logic 1 output. I would expect it to always be 0. When I set PWMMR4 to 100, it is always logic 0 output. I would expect it to always be 1. When I set PWMMR4 to 101, it is always logic 1 output as expected. Am I doing something wrong, or do I have wrong expectations? Thanks, Matt // PWM4 PINSEL0 = (PINSEL0 & ~PWM4_PINMASK) | PWM4_PINSEL; //PWMTCR = 0x5; PWMTCR = PWMCR_RESET; // reset & disable timer 1 PWMPR = PWM_PCLK_DIV - 1; // set the prescale divider ( 3-1 = 2) PWMMCR = PWM_MR0_R; // reset PWM0 when a match occurs PWMPCR = PWM_ENO4; // enable PWM4 output PWMMR0 = 100; // reset PWM0 every 100 ticks PWMMR4 = 50; // 50% duty cycle on PWM4 PWMLER = PWM_ENL4; // enable the pwm match register values PWMTCR = PWMCR_ENABLE; // enable pwm
