Lpc2000
How to detect a multiply overflow?
2005-08-09 by Aalt Lokhorst
Hello All,
I have concerns about a PID routine which is doing some calculations
with 32-bit values. It uses multiply and add instructions. My concern
about this is, how to detect overflow.
A overflow can result in a process correction with a wrong sign and this
is not acceptable for the process. What I need in a overflow situation
is a saturated value.
In the past I was using a 8052, multiplying 32-bit values was possible
but it was done in a lot of 8-bit portions.
With the ARM I can do the same in one instruction but I am missing the
overflow flag. Is there a option to detect an overflow after a multiply?
I am using the LPC2129 (ARM7)
Greetings
Aalt
Aalt Lokhorst
Schut Geometrische Meettechniek bv
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
E-mail: Lokhorst@...
Re: [lpc2000] How to detect a multiply overflow?
2005-08-09 by Anton Erasmus
On 9 Aug 2005 at 16:54, Aalt Lokhorst wrote:
> Hello All,
> this is not acceptable for the process. What I need in a overflow
> situation is a saturated value.
> but it was done in a lot of 8-bit portions. With the ARM I can do the
> same in one instruction but I am missing the overflow flag. Is there a
You can do a 32x32 bit multiply to get a 64 bit result. You can either use the 64bit result
directly or force the 32-bit answer to the maximum. If you are using gcc you
can declare your variable as a long long which is 64 bits.
  Anton Erasmus--
A J Erasmus
Re: How to detect a multiply overflow?
2005-08-09 by brendanmurphy37
In the general case, you're pretty much guaranteed overflow:
multiplying two numbers of a fixed precision (e.g. 16-bits) gives a
result twice that precision (in that case 32-bits). As another reply
has pointed out, you can simply declare the result to have twice the
precision of the two arguments. However, for 32-bit arguments this is
likely to be slow, as there's no native processing of 64-bit values:
the compiler will call an internal library function to do the math.
It might be worth your while looking at the "Enhanced DSP
instructions" (see ARM documentation from ARM): these provide various
forms of multiply and add, including some that saturate. The LPC2000
series as ARM7TDMI devices support these instructions.
A final thought that strikes me is that do you really need 32-bit
arguments? In general 16-bit is fine for most purposes as an input
resolution. You can still accumulate at 32- or 64-bits (scaling back
to 16-bits if further processing is required).
Hope this is of some help.
Brendan Murphy
--- In lpc2000@yahoogroups.com, "Aalt Lokhorst" <lokhorst@s...> wrote:
> Hello All,
calculations
concern
this
situation
possible
multiply?
> Greetings
> Aalt
> Aalt Lokhorst
> Duinkerkenstraat 21
> 9723 BN Groningen
> P.O. Box 5225
> 9700 GE Groningen
> The Netherlands
> Tel: +31-50-5877877
> Fax: +31-50-5877899
> E-mail: Lokhorst@S...
Re: [lpc2000] Re: How to detect a multiply overflow?
2005-08-10 by Aalt Lokhorst
Thanks for your answers,
I have tried the solution of Anton and I think this will do the job.
(See also the resulting assembler code further in this email)
At first I was thinking about a function which should estimate the
number of result-bits needed. (By adding the number of bits needed for
each variable without counting the leading zero's) This would be only a
rough estimation, see this example for two 3-bit values:
  100b * 100b =   10000b  (result 5 bit)
  111b * 111b =  110001b  (result 6 bit)
Adding the number of bits of both variables results in the worst case
situation. This is not ideal because there are situations which need a
bit less than the estimation shows I don't even mention the issues
involved with negative numbers.
Even if my 'solution' would work after solving all the issues then it
will be slow compared to a multiply with 64 bit result (and saturating
the result to 32 bit)
A small test shows the following:
void test (void)
   int32_t A, B;
   int64_t C;
   A = 0x12345678;
   B = 0x11223344;
   C = (int64_t)A * (int64_t)B;
Results in: (code for entering and leaving the function is stripped)
   A = 0x12345678;
    	E59F3038   ldr r3, [pc, #56]              ;R3 = 0x12345678
    	E50B301C   str r3, [r11, #-28]            ;write R3 to stack
   B = 0x11223344;
    	E59F3034   ldr r3, [pc, #52]              ;R3 = 0x11223344
    	E50B3020   str r3, [r11, #-32]            ;write R3 to stack
    	E3E0300F   mvn r3, #0x0000000F            ;some calculation of
    	E24B2018   sub r2, r11, #0x00000018       ;stack address for
    	E0821003   add r1, r2, r3                 ;the mul result
    	E51B201C   ldr r2, [r11, #-28]            ;get value 'A' in R2
    	E51B3020   ldr r3, [r11, #-32]            ;get value 'B' in R3
    	E0C65392   smull r5, r6, r2, r3           ;multiply R2*R3 and
                                                   ;put result in R5R6
    	E1A04006   mov r4, r6                     ;R4 = Result 'High'
    	E1A03005   mov r3, r5                     ;R3 = Result 'Low'
    	E8810018   stmia r1, {r3-r4}              ;store result
Not a bad result I think, no library function needed.
Brendan also wrote about "Enhanced DSP instructions" for the LPC2000
series. Such instructions are perfect for my application, but are you
sure the LPC2000 does support these instructions? I think the ARM7 does
not have such instructions.
And now the final question:
Do I really need 32 bit or even 64 bit intermediate results???
Well, actually almost never. My application runs fine with smaller
numbers if the closed loop process behaves correct. But if something
went wrong with a setpoint, the process or the PID-parameters then the
error-value can increase enormous and a integrator windup might occur.
I can check for all the problematic situations but it is a lot easier if
   the intermediate variables have simply enough bits to hold the 'worst
case' results, or if I could a use a 'saturate' solution.
Thanks for your help.
Aalt
Aalt Lokhorst
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
brendanmurphy37 wrote:
> Hi,
> Regards
> Brendan Murphy
>  > Hello All,
> calculations
> concern
> this
> situation
> possible
> the
> multiply?
>  > Greetings
>  > Aalt
>  > Aalt Lokhorst
>  > Duinkerkenstraat 21
>  > 9723 BN Groningen
>  > P.O. Box 5225
>  > 9700 GE Groningen
>  > The Netherlands
>  > Tel: +31-50-5877877
>  > Fax: +31-50-5877899
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-08-10 by Jerzy Lelusz
>                                                    ;put result in R5R6
I think it's excellent ;-)
> But if something
Isn't it easier just to limit error signal? So as long as error signal
is within certain limits there is no overflow. That's what I'm doing.
Also it's good to limit integration (to avoid windup problems).
Jerzy Lelusz
Electronics Engineer
Geola Technologies Ltd
Sussex Innovation Centre
Science Park Square
BN1 9SB Falmer, East Sussex
United Kingdom
phone: +44 1273 704 443
fax:   +44 1273 704 477
2005-08-10 by brendanmurphy37
I stand corrected: the "smull" instruction does indeed produce a 64-
bit result.
The LPC2000 series parts definitely do have the DSP extensions: we
use them in some of our signal processing software. I believe the "M"
in ARM7TDMI indicates this (I could be wrong on this).
Using saturated math can get quite messy: apart from the fact that
compilers generally don't support them well (if at all), you have to
be very careful about downstream effects if the result is fed into
further calculations.
I'd still be inclined to work at 16-bit values with 32-bit results,
as some operations on 64-bit values can be quite slow. I'm making the
assumption here that speed is of the essence: if not, there's no
problem with just getting the compiler and processor to get on with
it. Having said that, we've just completed a very acurate phase
measurement system using a LPC2134 that uses 64-bit intermediate
results, so I'm not really following my own advice.
Brendan
for
only a
case
need a
it
saturating
values:
math.
> void test (void)
>    int32_t A, B;
>    int64_t C;
>    A = 0x12345678;
>    B = 0x11223344;
>    A = 0x12345678;
>    B = 0x11223344;
>                                                    ;put result in
R5R6
LPC2000
you
does
something
occur.
easier if
the 'worst
> Aalt
> Aalt Lokhorst
> Duinkerkenstraat 21
> 9723 BN Groningen
> P.O. Box 5225
> 9700 GE Groningen
> The Netherlands
> Tel: +31-50-5877877
> Fax: +31-50-5877899
> > Hi,
a
reply
this is
values:
math.
various
LPC2000
back
> > Regards
> > Brendan Murphy
wrote:
> >  > Hello All,
> > calculations
> > concern
sign and
> > this
> > situation
> > possible
missing
> > the
> > multiply?
> >  > Greetings
> >  > Aalt
> >  > Aalt Lokhorst
> >  > Duinkerkenstraat 21
> >  > 9723 BN Groningen
> >  > P.O. Box 5225
> >  > 9700 GE Groningen
> >  > The Netherlands
> >  > Tel: +31-50-5877877
> >  > Fax: +31-50-5877899
> > YAHOO! GROUPS LINKS
2005-08-11 by 42Bastian Schick
brendanmurphy37 <brendan.murphy@...> schrieb am Wed, 10 Aug 2005
16:09:49 -0000:
> bit result.
          ||||_ ?
          |||__ HW multiply
          ||___ Debug (ICE)
          |____ Thumb
42Bastian Schick
2005-08-11 by Aalt Lokhorst
Hello
Well, I think I have two solutions.
  1 Limiting and probably scaling the numbers into smaller values.
  2 Go for the 32x32 multiply and saturate the 64 bit result.
I will look into it and make a choice. Both options are Ok I think, but
solution 2 has the advantage that I only have to limit the result. That
is no problem because the process 'actuator' has also it limits so it
will be 'saturated' anyway.
As Brendan already mentioned, saturated math can be messy if the results
are used for further calculations. Indeed, this is true, preventing such
  situations is the best solution. But if i have to choose between
'saturation' and 'overflow with inverted sign' then i will prefer
saturation.
Speed is also an issue for me but I have to investigate what I can
tolerate. The difference between my 8-bit processor history and the
32-bit ARM is so big that everything is relative. For the 8-bit
processor I used a 32-bit multiply routine which chopped the calculation
in several 8-bit chunks. It was written in assembly but still took a lot
of microseconds to execute. The ARM processor does the complete multiply
in less time than what the 8-bit processor needed to save some registers
  in preparation of the multiply.
Last year I attended a 'Hands on Training', this was my first experience
with the ARM processor. Olaf Pfeiffer from Embedded System Academy was
there to present the ARM processor. (Thanks Olaf it was a nice day, I
bet you are reading this forum) Olaf explained the letters TDMI-S:
ARM7TDMI-S
T = Thumb Instruction set
D = includes Debug extension
M = enhanced Multiplier
I = core has embeddedICE logic extensions
S = fully synthesisable (soft IP)
Aalt
Aalt Lokhorst
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
>  >                                                    ;put result in R5R6
>  > But if something
> Jerzy Lelusz
> Science Park Square
> United Kingdom
