Lpc2000
malloc external memory
2005-08-29 by szemzoandras
How it is possible to allocate memory in the external ram?
I'd try this
"-Wl,--defsym=__heap_start=0x81000000,--defsym=__heap_end=0x81ffffff"
Is it ok?
How can I mix internal sram with external space?
Thanks!!
Andrew
Re: [lpc2000] malloc external memory
2005-08-29 by Charles Manning
On Monday 29 August 2005 23:20, szemzoandras wrote:
> Hi,
> I'd try this
> Is it ok?
> Thanks!!
This is too little information to work from.
malloc is a library function that is implemented differently by different
development tools and the symbols you set will vary accordingly.
Re: malloc external memory
2005-08-29 by Ken Wada
--- In lpc2000@yahoogroups.com, "szemzoandras" <a.szemzo@k...> wrote:
> Hi,
> I'd try this
> Is it ok?
In general, you need to call some kind of subroutine to properly
initialize your heap/memory manager. Since I do not know which tool
you are using, I cannot give you more information here.
Absolutely, I do this all the time. What exactly do you want to do?
Ken Wada
> Thanks!!
> Andrew
2005-08-30 by szemzoandras
hi,
I'm using winarm package, so gcc is the compiler.
I would like to use internal SRAM for the local variables, etc..
but I need some relative big blocks of memory stored in the external
memory.
I can read/write external memory "by hand", but I think I don't need
to write a memory manager, I can simply use malloc. (I hope)
I have one question, how? :)
sa@m
> > I'd try this
> > Is it ok?
> Ken Wada
> > Thanks!!
> > Andrew
2005-09-16 by Ken Wada
If you are using the GNU tools then in general, you need to do the
following:
1.  Modify the malloc_init() code that is located with your GNU
development kit.
2.  Make any necessary modifications to the malloc_memory code that is
also included.
3.  Make sure that your heap is properly located, (do this in the
linker descriptor file, that is the ASCII script file that tells the
linker/locator how to properly link/locate your project)
Since I am not using the GNU tools for the Philips LPC2xxx, I cannot
give you much more information than this. I have extensively used the
GNU tools for other processors though...and what I am describing is
pretty common for the GNU tool chain.
oh...By the way, there are other things you can do. Sometimes, my
clients tell me that they will not approve of anything I do if it
incorporates malloc() and free(). In this case, I create my own static
memory allocator...this usually solution works very well, plus, I can
customize the allocator to look for heap/memory corruption, memory
leaks and a bunch of other stuff!
Ken Wada
> hi,
> memory.
> sa@m
> > > I'd try this
> > > Is it ok?
tool
do?
> > Ken Wada
> > > Thanks!!
> > > Andrew
