GNUARM died after Cygwin reinstall?
2005-08-31 by DECwiz (Fred van Kempen)
Hi All, Some times are just weird.... I was happily running GNUARM 3.4.3 on my laptop, with a full install of Cygwin (a leftover from my adventures with Eclipse, it ran fine without that as well, when I just checked the 'install Cygwin libs' box during install.) Then, three things were done on that laptop: - I upgraded the virus scanner to a more recent version - I un-installed the Cygwin stuff, as it was __large__ and completely unused, other than the DLL's for GNUARM, and then re-installed GNUARM 3.4.3, but with the checkbox set, for local libs. - I also installed MSPGCC, for the TI 430, which also uses (its own copy of) the Cyg dll's. Now... since that, I am no longer able to run GCC. Not the ARM version, and not the MSP version. I uninstalled the lot, reinstalled only GNUARM, even tried one with (again !) the entire Cygwin system... nada! GCC kinda works, or, rather, all the small tools seem to work, but GCC itself bombs out when trying to compile just about anything: -------------------- arm-elf-gcc -mcpu=arm7tdmi -mthumb-interwork -std=gnu99 -Os -gdwarf- 2 -Wall -msoft-float -Wstrict-prototypes -Wimplicit -Wshadow - Wunused -Wmissing-declarations -Wmissing-prototypes -Wnested- externs -Wpointer-arith -Wredundant-decls -Wreturn-type -Wstrict- prototypes -Wswitch -I./include -DE2294 -I. -c conf.c -o conf.o arm-elf-gcc: Internal error: Segmentation fault (program cc1) Please submit a full bug report. See <URL:http://gcc.gnu.org/bugs.html> for instructions. --------------------- As said, I have tried just about every combination of install sequences, including disabling the virusscanner, to no avail. Is there a way to track down where cc1 is dying? It could be that it is trying to load a Cyg dll that doesn't exist, for example, but how do we check/trace that ? Thanks lots for any help, Fred [Non-text portions of this message have been removed]
