Is manual clearing of MAT0.1 possible?
2005-08-31 by Brian C. Lane
I'm trying to run a AD conversion off of a timer match. The AD is set to start on MAT0.1 going high. It only goes off once though :) If I set the timer to toggle MAT0.1 it runs, but at 1/2 the desired rate (only on the high edges). Can I manually clear MAT0.1 so that it will go high on the next one? Or do I have to do a kludge like changing the A/D trigger to go off on low then next time, etc. (ick!). Thanks, Brian -- ----------------------------------------------------- Brian C. Lane (W7BCL) Programmer www.shinemicro.com RF, DSP & Microcontroller Design
