Keil MCB2130 Reset Problems?
2005-09-02 by Brian C. Lane
I'm not sure what's going on here, but I appear to be having a reset problem with the Keil development board. I am using CrossWorks for the ARM and a Olimex Parallel JTAG adapter, or a USB CrossConnect (both exhibit the same problem). On initial powerup, download of code and debug the code runs as expected (some interrupt code and a counter to indicate that the interrupt is being run). If I recompile (with or without change, it doesn't matter) and reload it then sometimes the code won't work. Or will partially work (eg. running in the main loop flashing LEDS ok, but the irq isn't executed -- counter is at 0). I've tried various combinations of stopping and reloading, software reset of jtag adapter, etc. Pushing the reset button on the board, etc. The only thing that consistently works is pulling power from the board before reloading. If I have to do that every time I change the code I'm going to go nuts. Has anyone seen this before? Or has any ideas? Thanks, Brian -- ----------------------------------------------------- Brian C. Lane (W7BCL) Programmer www.shinemicro.com RF, DSP & Microcontroller Design
