[gnu-arm-lpc21XX] a suspucious compile error?
2005-09-10 by Mukadder Ceyhan
hi everybody! I succeded to install eclipse-gnu-arm toolkit as tutored in olimex website. then i compiled the example program guided in pdf tutorial:lpc2106_blink_led program. then i made a sample program piece such that to check standart c functions: such as memset,memcpy etc.. my first try was this: char buffer[20]; ... memset(buffer,0,sizeof(buffer)); this code does not working!!!while compiling gcc gives this message: memset referencing error! what is the solution? how can i fix this problem? is this due to the compiler? thanks... ______________________________________________________ Click here to donate to the Hurricane Katrina relief effort. http://store.yahoo.com/redcross-donate3/
