Lpc2000
hex file with keil µvision3
2005-09-12 by preciamolenap
hi,
I'm writing my one bootloader. My bootloader take code througt the UART
and program the external flash.  So i need myproject.hex. The .hex file
exist but he is empty, the information seems to be in myproject.elf.
Is it possible to have the .hex file (with Keil) without the .elf
file.  And how is the file format?
Thanhs
Alexandre
Re: hex file with keil µvision3
2005-09-13 by mpwalter2005
Hi Alexandre,
you can generate the hex file from your code. make sure you have
selected "generate hex-file" under the TOOL OPTIONS - OUTPUT. The file
who keil generated is an Intel Hex File (try a simple search as
google: eg. intel hex file) and you will find converters and documents
about this.
Hope this will help you
Matthias
--- In lpc2000@yahoogroups.com, "preciamolenap" <alexandre.petit@p...>
wrote:
> hi,
> Thanhs
> Alexandre
