Lpc2000
Interrupt simulation
2005-09-14 by nuncio_bitis
Is it possible to simulate interrupts in the Insight debugger? I'd
like to somehow fire an IRQ interrupt.
USB Philosophical Question (slight OT)
2005-09-14 by James Dabbs
We'll looking at the Phillips LPC2148 for a rackmount device where we're
considering using USB *instead* of DB9 (9600,N,8,1) for local
configuration and diagnostic support.
Has anyone here considered this type of application for USB?  Any
insight is greatly appreciated.
Re: USB Philosophical Question (slight OT)
2005-09-14 by lpc2100_fan
James,
a UART is great for point to point connections, a USB is not, unless
it is USB OTG.  If you use USB you would need to implement a Host that
controls it all and lots of devices "slaves".
Did you consider CAN? IMHO the price overhead for CAN and USB are
similar, both being about +$1 over a UART implementation.
If you have a centralized system where one Host ("master") has control
over everything, this approach could be interesting.
Please keep the group posted, at least I am very interested in the
challenges and opportunities of such an approach.
Bob
RE: [lpc2000] USB Philosophical Question (slight OT)
2005-09-14 by Dan Beadle
This is certainly doable.  The issue is getting the USB stack.  The IAR
and Keil samples implement HID and Mass Storage devices, but not a
communications controller. Certainly, the hardware is capable of doing
Serial Emulation.
The other issue is ISP.  If you want to change your code, the two easy
ways are ISP or JTAG.  So you might want to expose either of those
connectors.  On a design I have in process right now, I am bringing out
Serial 0 with RTS to enable ISP for the early versions of the product -
a safety net for field upgradability.
The elegant solution that I is in my product spec is to support IAP via
USB to allow the program to be updated.  Ideally, Philips would make a
USB version of the boot loader
Dan
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of James Dabbs
Sent: Wednesday, September 14, 2005 5:06 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] USB Philosophical Question (slight OT)
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
> support IAP via USB to allow the program to be updated.
> Ideally, Philips would make a USB version of the boot loader
How far out is this?
